jd 870 hydraulic problem with fel
   / jd 870 hydraulic problem with fel #1
joettt
cleveland texas
jd 870
the fel on my jd 870 operates very slow both opening/closing and lifting/lowering need help trouble shooting and testing.
   / jd 870 hydraulic problem with fel #2
This is what you have.
Hydraulics:
Type: open center
Capacity: 5.5 gal [20.8 L]
Pressure: 2250 psi [155.1 bar]
Valves: 2
Pump flow: 8.1 gpm [30.7 lpm]
If the fluid is cold, it will be slow.
If it still slow when the fluid is warm, then check the pressure relief.
It will be hard to know pump flow unless you do a pressure and flow test of have someone do it.
Check fluid levels.
Check all filters and sump screen if your tractor has them.
thank you for your help. I will start checking filters and screen. I am going to buy pressure gauge and see about obtaining flow meter. I forgot to say that bucket lift bleeds down very fast I have to keep using the control lever to keep the bucket up while moving. do you know what fittings I will need for the pressure gauge connections.
   / jd 870 hydraulic problem with fel #4
If the loader is lowering that quickly then you probably have fluid leaking past the cylinder seals... that in itself will make it slow. The other possibility is the valve, but the cylinder is more likely.
My 1070 would hardly lift the empty bucket, (partially) took apart the valve and found that a plug had fallen out. The plug was internal to the valve to bypass for certain options.
   / jd 870 hydraulic problem with fel #5
It would depend on the gauge size, and the QD or the tee fitting.
You can make a portable tested or install the gauge in a tee in the IN port of the loader valve . This way, you can check out anything hyd on the tractor.
The QD plug in only checks what you plug into.
Your loader drift down could be caused by cyl seals or worn spool valve.
2011 JCB 541-70 TELESCOPIC FORKLIFT (A51242)
2011 JCB 541-70...
2018 Toyota RAV4 SUV (A50324)
2018 Toyota RAV4...
2020 FABRIQUE H9618TRTV-100 18FT ENCLOSED TRAILER (A51222)
2020 FABRIQUE...
2013 Jeep Patriot (A50324)
2013 Jeep Patriot...
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
2022 ISUZU NQR 18FT FLATBED (A51222)
2022 ISUZU NQR...
