SUDT2 versus Universal Hydraulic Fluid
   / SUDT2 versus Universal Hydraulic Fluid #71
So is SUDT2 fully synthetic or synthetic blend?
40 gallons i just choked a little.
I thought the 17 gallons our tractors hold was expensive.
i have the SUDT2 in my M8540 its slightly better but in cold weather but around say <10 ーF i still have to warm up for 10 minutes or i get pump whine and both the main shift and even the range select are extra sticky. At 600 hours I'll got to AMSOIL or install a heater into the side case drain. maybee I'll do both i hate pulling the drain plug. I also have a Fumoto valve to install.
Dave, if you switch to AMSOIL post a thread and discuss the noted differences.
Good question. I just read the jug and it doesn't claim either. So I'm guessing it's a blend. I think they'd brag about it on the jug if it was more than that. :confused3:
   / SUDT2 versus Universal Hydraulic Fluid #74
OK, so UDT and SUDT are dyno, and SUDT2 is a synthetic blend.
In this case, paying extra for 100% synthetic AMSOIL might be a good investment.
I would love to hear from anybody who has used both SUDT2 and AMSOIL.
Also, my tractor calls for SUDT2 in the front axle, can I substitute with the AMSOIL I will be using in the HST?
   / SUDT2 versus Universal Hydraulic Fluid #75
Howdy ovrszd,
I will definitely start a new thread when if and when I do this. I'm hoping that i will have my tractor paid for by the time i hit the 600 hour mark.
   / SUDT2 versus Universal Hydraulic Fluid #76
From what little I have read about SUDT2 it is 75% synthetic.
   / SUDT2 versus Universal Hydraulic Fluid #77
I use, and have always used John Deere Low-Visc Hy-Gard In all the tractors I have (had). Over 7K hrs. and not problem, I don't know who makes there oil but will bet JD keeps a tight rein on the spec's. Also, It cost less than SUDT2:)
David
We have had excellent success with just upgrading deere ag tractors from the hygaurd to the hytran from Case-IH. Kubota would be an upgrade over the Hytran. Your call. Deere's oil has not been outstanding when testing. Good, but not great.
   / SUDT2 versus Universal Hydraulic Fluid #78
Does anyone know what Kubota fills the grand L's with at the factory?
They all come through with the superUDT as they might go any where in the world.
   / SUDT2 versus Universal Hydraulic Fluid #79
Do you have a copy you can post of this JD oil test your refer to??
   / SUDT2 versus Universal Hydraulic Fluid #80
So I guess the sudt2 I have waiting at home will be an upgrade. That's nice to hear for what it cost.
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2006 International 9400i (A51039)
2006 International...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
SDLG WHEEL LOADER FORKS MAST W/ 48" FORKS (A51242)
SDLG WHEEL LOADER...
