Backhoe Ford 555 front axle wanting to seperate from the block
   / Ford 555 front axle wanting to seperate from the block #11
It could be thread crush. Swarf from the manufacturing process could contribute to "false" torque values on first tightening. The solution in the past has been to torque them up then remove completely and reinstall and retourque.
   / Ford 555 front axle wanting to seperate from the block #12
The parts catalog specifies grade 8 hardware and no washers, either flat or lock. Lock washers are a bad idea, USS spec washers probably won't fit flat on the castings. I was thinking that two of those bolts should be surrounded by hollow locating dowels, but I can't find them in the parts catalog. If they are required but missing, that is likely to be a large contributing factor. If you are re-using old bolts, toss them and get new ones. Tighten things up and measure the joint with a feeler gauge to see which, if any, shims are required. usually there are none in this location. Keeping this interface tight normally is not problematic.
Are they true 3/4" x 2.75"
If you happen to have the bolt size from the parts catalog that would be great if you could share
   / Ford 555 front axle wanting to seperate from the block #14
How about wire lock bolts? You could even tie them to each other to cancel forces.
Dave
Like a bolt with a hole drilled through the head for a wire / cotter pin ? not sure if there is such a thing
I have noticed that the size of bolt that it appears to take is not standard at .75 x 2.5
   / Ford 555 front axle wanting to seperate from the block #16
I think you are on the right track. If it indeed is missing shims the bolts will never stay tight, not all assembly's required shims.
To apply the torque properly it would be best to have the machine raised so that the front is not carrying any weight.
Also have a look at the axle pivot joint, excessive play here can cause all sorts of trouble.
   / Ford 555 front axle wanting to seperate from the block #17
New Holland lists the bolt as gr. 8 3/4-10 X 2 3/4". It also shows a flat washer and 5 different shims that could go in between the support and the oil pan. The bolts that go through the block have nuts. There I would use gr 8 locknuts and locktite.
Gary
New real grade 8 bolts and 2 cans of break parts cleaner and red loc-tite seem to have fixed the problem ...
thanks to all
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
40 Dry Van Enclosed Trailer (A57453)
40 Dry Van...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
