Separate top hydraulic mount on LA525 Loader
   / Separate top hydraulic mount on LA525 Loader #1
vtwinhd
Member
Grafton, OH
Kubota L3901
Anyone have any idea what the second top mounting hole for the hydraulics on the arms of the FEL are for. Is it possible to move them to gain some type of mechanical advantage. Maybe i'm looking at it wrong but it def looks like a second location to bring the top part of the piston up around 6 inches. I may have missed that in the owners manual. I wish i knew how to post a picture.
   / Separate top hydraulic mount on LA525 Loader #2
I'm acually talking about on top of the loader arms there is the big bracket the holds the top of the hydlolic
Right above the letters "LA" where is says LA525
   / Separate top hydraulic mount on LA525 Loader #5
I assume those holes were either used in fabrication (to line up for welding or support the parts for painting) or are blanks for a different model/application. You will notice they do not have a reinforcing boss welded on to accept a pin -- they are simply holes punched into the metal sheet. So they do not have an alternate use for mounting a cylinder in this case -- there is not enough meat there to qualify as a mounting point.
Look closely at the engine and rest of the tractor and you will see unused holes and blanks all over the place. Some holes are threaded and have a plastic plug painted over. Heck, even the engine has multiple places for fill caps, dipsticks, etc that are not in use. This type of equipment has lots of variations -- for example the same engine may be used in a tractor, generator, boat, etc, and it's very typical to see lots of extra mounting options. Don't assume they have a purpose in this model/application.
I remember one person here posted about missing bolts on some part of a Kubota just because there were empty threaded holes. Not something to really get concerned about. You'd need a few dozen bolts to fill all the unused holes on my Kubota and there wouldn't be a point.
Really good point I'll forget about it and get back on the horse .... Um Tractor
Show Livestock Tie Up Rack (A50515)
Show Livestock Tie...
2015 Jeep Compass Latitude SUV (A50324)
2015 Jeep Compass...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
3-Point Bale Spike and Kroyker Loader Combo - Includes Trailer Hitch Adapter (A51039)
3-Point Bale Spike...
12in Digging Tooth Bucket Excavator Attachment (A50322)
12in Digging Tooth...
Adams 8 Ton Weigh Hopper (A52128)
Adams 8 Ton Weigh...
