2009 Mule 3000 won't lock into forward gear
   / 2009 Mule 3000 won't lock into forward gear #1
Zkat
Smitville, TX
Kawasaki Mule 3000
I'm having an odd problem with our VFD's mule. It won't lock into forward. It locks into reverse just fine. I removed the shifter cable and tried shifting it by hand and sometimes I can get it into gear. Once it's in it's fine. Anybody ever encounter this before? is there a ball detent on the shifter that can be replaced? If so is it a cast iron b**ch to get to? Our VFD really needs this vehicle to be up so any help would be greatly appreciated.
   / 2009 Mule 3000 won't lock into forward gear #2
What happens when it won't go in, does it pop out, or not go in at all?
How tight was the shift linkage?
Aaron Z
Pops out and grinds. The lever moves easily enough and snaps into reverse just fine. the detent seems to click in both directions. If I snap it into drive it works sometimes and you hear the same internal click you do in reverse.
   / 2009 Mule 3000 won't lock into forward gear #4
:welcome:
To the forum from Alabama.
Found it. Babbit's calls it "Lever-Comp FR/RR" and it is the little bugger that the shift lever attaches to. The little pawl on the inside had broken and was wallering out the hole. That gear box is a sod to remove.
2019 KOMATSU PC170LC-11 EXCAVATOR (A52707)
2019 KOMATSU...
2022 Chevrolet 1500 Silverado Crew Cab 4X4 Pick-Up Truck (A55852)
2022 Chevrolet...
2016 Ford F-150 4x4 Pickup Truck (A55852)
2016 Ford F-150...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2020 Terex RL4 Towable Light Tower (A55851)
2020 Terex RL4...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
