Loader Mahindra 4025 aftermarket loader
/ Mahindra 4025 aftermarket loader #1
wbjdmd
Carrollton, MS
Mahindra 4025 2WD
I am looking for a loader for my 4025 2WD that I just got. Any suggestions on good aftermarket loaders(or other equipment)?
/ Mahindra 4025 aftermarket loader #2
:welcome:
Welcome to the forum from Northwest Alabama. I am over in Tupelo a lot and down to Columbus AFB sometimes.
/ Mahindra 4025 aftermarket loader #5
What's wrong with the stock Ansung?
Not sure what stock ansung is? Sorry. If this means mahindra loader, I was looking for a potentially cheaper alternative.
/ Mahindra 4025 aftermarket loader #7
You may have to forget about Westendorf then. Their loaders are not cheaper.
/ Mahindra 4025 aftermarket loader #8
My Kubota Grand L3130 came new with a Bushog Loader. It has the skid steer quick attachment and is easily removed. After 9 years it has never given me a problem, very well built.
/ Mahindra 4025 aftermarket loader #9
Ansung makes the loader for the 4025.
/ Mahindra 4025 aftermarket loader #10
Buehler made mine, no issues 4.5 years since new. I think is spelled "Buehler" correctly. It is branded as Mahindra.
/ Mahindra 4025 aftermarket loader #11
Same here on my 2008 Mahindra 5525. No problems in the 6 years I owned the tractor. Added the skid steer quick attach option.
/ Mahindra 4025 aftermarket loader #12
Buhler is now Allied. I doubt they'll be any cheaper either.
/ Mahindra 4025 aftermarket loader #13
I don't think any loader is "cheap" any more. Seems like the best way to get a deal is buy it with the tractor.
/ Mahindra 4025 aftermarket loader #14
Whichever you choose, be sure to get the correct mount/loader. There is a difference in the 2wd and 4wd loaders.
/ Mahindra 4025 aftermarket loader #15
I think you will find it hard to find a cheaper alternative to the Mahindra original. Usually the aftermarket is higher when you have the full package put together.
/ Mahindra 4025 aftermarket loader #16
I like Koyker loaders. They have always priced out good for me with strong specs.
/ Mahindra 4025 aftermarket loader #17
Really? I've pored over the specs on paper a few times I couldn't really find any differences that seemed significant. Maybe I've overlooked something.
D
/ Mahindra 4025 aftermarket loader #18
I believe the difference is in the mount, not the actual loader, although I could be wrong. The 4wd sits higher. If the 2wd loader is mounted by mistake, the bucket won't touch the ground with the cylinders bottomed out. The factory loader for the 2wd is model ML333, for the 4wd it's ML334. BTW, those are new model numbers. Not sure they're even on the website yet.
/ Mahindra 4025 aftermarket loader #19
So you're saying with the loader all the way down, the heel of the bucket should contact the ground? The loader that came with my 4025 4wd is called the 4550-4L. I can only reach the ground if I roll the bucket forward.
/ Mahindra 4025 aftermarket loader #20
I am not familiar with the 4550-4L loader. Is that a new Mahindra brand loader? The model # is different from all previous that I have seen or read about.
