BX25 Snow pusher
/ BX25 Snow pusher #1
Jj1479
Hooversville PA
Kubota bx25
Just some pics of a snow pusher that I had made for my bx25. Made it heavy duty so I could use it for dirt also. I just copied off of the one's they use to clear the parking lots at the malls.
100_0871.jpgiphone 159.JPGiphone 161.JPGiphone 162.JPGiphone 163.JPGiphone 164.JPGiphone 165.JPGiphone 182.JPGiphone 168.JPGiphone 166.JPGiphone 184.JPGiphone 183.JPG
/ BX25 Snow pusher #3
Looks good! I'm curious where you got those right angle magnet clamps? And do you like em or are they just ok?
/ BX25 Snow pusher #4
Do you have any pics of it on the tractor? How wide did you go?
/ BX25 Snow pusher
I'll post some more picks when I get back home. I think I only went 6" wider on either side of the bucket if I remember. Those were picks from last year when I first built it.
/ BX25 Snow pusher
Looks nice, weld me up a couple.
I had $117 worth of steel from the scrap yard for that an had steel left over. If it wasn't so match to ship I would build you one for cost of materials/paint as I like fabricating things. It keeps me from getting board.
/ BX25 Snow pusher
They talked me into getting 2 when I bought my Lincoln powermig 255c and then found 3 on Craig's list for $200 an a long drive an the rest trolling eBay . Apparently people don't know that they cost $187.15 each at cyberweld website. They are awesome an hold up to 150lbs. An you can turn then on an off.
/ BX25 Snow pusher #8
Am I correct in that you cut partially thru the plate in order to then bend it to desired angle? followed by welds?
If so cool, I also do that when the material is stiffer than I can handle otherwise.
In fact that is a very good tip for many DIY guys.
At worst I grab 2 pipe wrenches and an angle (for backer) and fold 4-5 ft of flat stock.
Also made plow skids by cutting 1/2 way thru 1/2" stock, bent in vice and then welded back the gap to strengthen the skids. Worked fine.
/ BX25 Snow pusher
Yes I cut 2/3rds of the way through then put the bucket on it an used a big crescent wrench to bend it up. Then back step welded it to keep it from warping from to much heat.
/ BX25 Snow pusher #10
Thanks so much for the magnet info, ill keep my eyes open for em. It certainly is satisfying to take a few pieces of steel and turn into something useful.
/ BX25 Snow pusher #11
Hi Tags horrible fright (harbor freight) has about 3 different sizes no way as fancy but not same price league either
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Mahindra Emax 22S Loader Tractor (A66285)
Mahindra Emax 22S...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
NEW Rachet Tie Downs and Flatpack Tool Box (A62679)
NEW Rachet Tie...
Rake Master CR-50SG-LD (A64126)
Rake Master...
