Price Check JD 2320 alternator and block heater pricing
   / JD 2320 alternator and block heater pricing #11
I had a block heater added to my 2520 this summer before I took delivery and although I can't put my hands on the sales receipt it was ~$80.
Parts tells me the block heater requires 3 separate packages - the heater, the cord, the gasket and some screws. For a complete kit it's $150. Couldn't get the salesman to verify a possible mistake on the $477 but I've pretty much decided I'll not bother with this anyway.
Thanks for the feedback everyone.
Fascinating stuff here - I was sleepless and got reading about the cab that was fabricated for the 2320 - very impressive. I can't wait to start some of my own fabrication projects for this toy. :D The first will be a ballast that can also double as a kind of tray or small shelf for transporting items such as a rear end, a sheet of plywood etc. I have some 1" thick plate that will be the starting point. Any such item been built before?? How about adding a hitch receiver to the iMatch itself??
Jack
   / JD 2320 alternator and block heater pricing #13
Jack
I checked my local dealer's pricing on the block heater through Deereparts.com. $150 is essentially correct, although I come up with two part numbers to get to that total; an adapter kit and the heater kit which comes with the cord. AM134805 and AR87167.
Thanks guys. I will now forget this issue and hopefully start playing with my toy on Friday.
Is there anything to be watchful for when picking up the tractor. I suppose it should be nice and clean and unscratched etc. My wife is very particular and will be along so sometimes that creates a little tension (makes me think of a recent new car purchase where the dealer showed us the freshly washed car in their service bay and let us inspect ; and inspect she did ;))
I haven't been sleeping well lately!
Jack
   / JD 2320 alternator and block heater pricing #15
I upgraded to a 50 amp alternator from the usa. Just search yanmar alternator or John Deere 2320 alternators on ebay. It will give you the alternators that fit right on. I got mine from Rarelectical.
   / JD 2320 alternator and block heater pricing #16
For around $100.
Schulte XH1500 Series 4 Pull-Behind Batwing Rotary Brush Cutter Tractor Attachment (A59228)
Schulte XH1500...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Toro Groundsmaster 7200 72in Zero Turn Commercial Mower (A59228)
2018 Toro...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
2004 Pierce Tilt Crew Cab Pumper Fire Truck (A59230)
2004 Pierce Tilt...
