Additional weight for 6' rear blade
/ Additional weight for 6' rear blade #1
carrolle
fredericksburg,va.
John Deere 5205
Does anyone have any suggestions about how to add weight to my 6' Bush hog rear blade. Pics. would be much appreciated . Thanks Carroll
/ Additional weight for 6' rear blade #2
On my 6' rear blade in the spring I am going to mount railway track (the additional 160# should help it) to the concave side with hangers so it can be taken off for the winter.
/ Additional weight for 6' rear blade #3
I mounted an old concrete wheel weight in between the arch of the main frame of my 6.5 ft GB. Had it temporarily attached with a ratchet strap, till I found it was just what I needed to make it work. Then thru-bolted it to the frame after.
Shadow
/ Additional weight for 6' rear blade #5
A hydraulic top link would do the trick.
/ Additional weight for 6' rear blade #6
I just draped my loggin chains on the back blade frame for weight. The plus side is I have the chains ready for something'.
/ Additional weight for 6' rear blade #7
The hydraulic top link will make the rear blade a lot easier to use, but it won't add cutting force like additional weight will unless you have one of the odd tractors that has 3 point down force - most float when lowered.
/ Additional weight for 6' rear blade #8
If you are looking to get better cutting action you could try adjusting the top link to angle the blade edge away from vertical.
Sent from my iPhone using TractorByNet
/ Additional weight for 6' rear blade #9
Yeah I see now :)
/ Additional weight for 6' rear blade #10
Now why didn't I think of that. I'm gonna use that until I can get to the welding shop.
/ Additional weight for 6' rear blade #11
I welded some angle iron to mine to make trays to hold 2 heavy concrete post footings. They can be removed if needed, but so far they are just about the right weight for most of my chores that I use the blade for. Buying a box blade w/rippers has been what I use now for really heavy duty work though. My angle blade only does snow, leaves, ditches and light scraping since I got the box blade.
God i love this forum, so many members with great ideas and willing intelligent responses. Thanks ! I am just now learning how to weld and these pics. will be a great help. One more question , how do i attach photos to my posts? Carroll
/ Additional weight for 6' rear blade #13
