My heater and LEDs
/ My heater and LEDs #1
OrangeJbird
NW WI
3320 w/300cx FEL
Some pics of my LEDs and heater.
I got the LEDS on Ebay for under $40.00. 2-18 Watt slims on the front and an 18W round on the back.
The heater is a $10.00 swap meet find and I used a vacuum cleaner hose I had laying around to put heat to the other side of my enclosure. The pictures don't really show how much more the front LEDs light the area ahead, but they do!
3320 Deere.
Toasty!
https://www.youtube.com/watch?v=RdY1AQ2u7NQ&feature=youtu.be
/ My heater and LEDs #2
If you really need to warm up fast take the end of the vacuum hose and run it up a pants leg! :shocked:
I can stick it just-a-bout anywhere! :laughing:
/ My heater and LEDs #4
May be someone on the forum works for NASA and can get you a used space suit to wear in cold weather where you can just plug in your heater hose! It would double as a great costume for Halloween also.....:D
/ My heater and LEDs #6
That's sweet the heat is going to make it much nicer. I just did the same thing as u except I purchased the factory heater. I did not get any where near as good a deal as you. I did well on the lights though. I'll post pics when i can.
/ My heater and LEDs #7
I like those 18 watt slims, was thinking on 18 watters, I now have 27 watts in the front,
and wanted 18's for the rear, just wasn't sure if they were bright enough, they are, thanks.
/ My heater and LEDs #8
Ratings on LED lamps can be misleading. A 27W lamp may only draw 1.5A. I found this out when playing with some I bought. They rate the power as "9 x 3W LED inserts". However they do not drive them to anywhere near 27W. Mine where only drawing 1.25A.
Weedpharma
/ My heater and LEDs #9
Am I missing something... I assumed all factory cabs came with heat? A/c I could see being an option, but heat?
Those lights look nice btw... what brand are they. I was looking at some "nilight" ones on amazon, not sure if they are any good though.
http://www.ebay.com/itm/2PCS-6INCH-18W-LED-WORK-LIGHT-BAR-SPOT-DRIVING-LIGHTS-OFFROAD-
Here's a seller that has them. I paid $22.00 from a different seller who now lists them for $35. Demand must be good.
My "cab" is a soft cab. See my avatar.
FOG-4WD-BOAT-UTE/261503240275?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20131003132420%26meid%3D8bf9f1ca739447e2a807f4f4c122bc9e%26pid%3D100005%26prg%3D20131003132420%26rk%3D1%26rkt%3D6%26mehot%3Dpp%26sd%3D261636687245&rt=nc
/ My heater and LEDs #12
Ok, well that link says the item is no longer viewable.
/ My heater and LEDs #14
/ My heater and LEDs #15
/ My heater and LEDs #16
Do you have any idea what that heater was made for. It looks like a nice compact unit. I take it that it is hooked to your cooling system and is not electric.
It's a old old sears unit from many years ago. Probably meant to go in an old pickup that didn't have a heater. I got it cheap at a swap meet. The fan was gummed up so I had to free and lube it. Works great! Ran 5/8 heater hose from the engine.
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
JOHN DEERE C6R36" CORN HEAD (A64278)
JOHN DEERE C6R36"...
2022 EZ-GO ELITE...
Barrel (A64557)
Barrel (A64557)
1996 Chevrolet Astro Cargo Van (A64194)
1996 Chevrolet...
2025 SDLANCH Rachet Tie-Down Strap (A64194)
2025 SDLANCH...
