Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #2,401
Looks good HEC! What kind of cutting edge do you have on your bucket of the M5700??? I have been looking at putting some sort of pipe over mine for plowing on gravel and grass.
A friend gave me a piece of 2 inch pipe which I slotted with a torch to fit over cutting edge . If you cut it with a torch do it in sections as it will bend other wise ( don't ask me how I know ) . It did straighten out fine though . It works really well on grass and on my gravel drive while things freeze up then I take it off . I put one on my back blade of the 2650 and that works great also .
   / Pictures of your snow weapons #2,402
It is too bad that tire chains that fit the tires are not readily available. Seems to be a "One size" fits all approach.
That is a very nice set up you have (Beenthere), I would like the hyd. angle on the back blade for sure . It is a pain getting in and out when I want to change angles but I can't have everything , very fortunate to have what I do . I have never needed chains in the past 25 years with 4wd and for the 2 good size storms we just had I didn't need them with 2650 either . My driveways are long but pretty flat so that helps for sure .
   / Pictures of your snow weapons #2,403
HEC
You may be referring to the post by jgayman #2384 (p239) that I quoted showing his JD 2720 snow weapon.
   / Pictures of your snow weapons #2,404
FINALLY we got some real snow in north idaho. Had about 8" fall overnight.
   / Pictures of your snow weapons #2,405
Nice pictures especially with the pines and everything with a fresh coating of snow. Are the tracks in the last picture deer?
   / Pictures of your snow weapons #2,406
na...those were my golden retriever...he loves fresh snow
   / Pictures of your snow weapons #2,407
Nice snowfall. Been a month since we've had any. Hoping the New Year will bring some more.. soon.
   / Pictures of your snow weapons #2,409
There are deer and moose tracks in my back woods....all over the place
   / Pictures of your snow weapons #2,410
The nine year old takes it off the walks and the three year old puts it back on, it doesn't get better than that!
   / Pictures of your snow weapons #2,413
I was asked on another thread to post pictures of the mods I did to my Agri-Fab 50" snowblower so here they are.
The primary modification was to add two slots (one additional per side) on the chute "gear" so it would go ~120 degrees from forward. Without the additional slot, it only goes ~90 degrees and that just isn't enough in some cases. I had to remove the metal stop plate that bolts on the right side of the chute "gear" and grind off some plastic that is moulded into the "gear" on the left side. They keep the chute from rotating past 90 degrees but aren't necessary since the turner runs into the edge of the "gear" and can't turn it farther with no slot to engage. I did this with my Dremel tool.
Right side. The metal stop plate was held on by the two rightmost bolts. I had to grind the washer that was right were I needed to add the slot.
Left side
The "stop" that was part of the plastic gear was just to the left of the slot I added. Both stops ran up against the vertical plate on the blower housing. If you look closely at the washer right where the camera flash inconveniently landed, you will see that I also had to grind off part of that washer as well. It stuck out into the slot and the "turner" would hang up. Can't say this is the best design.
I added the recommended "wheel weight kit" - 55 pound wheel weight bolted to the back of the tractor. The instructions say to mount it angled this way if the gas tank interferes. It doesn't but the holes in the bracket didn't line up with those in the tractor when I tried to mount it straight out. BUT, that turns out to be a good thing because it wouldn't have left enough space to hitch the dump cart to the tractor. I'm using it to haul firewood up to the house.
This product uses a stock electric winch (used on ATV I guess) to raise and lower the blower. Clearly not made in the USA given the instructions are REALLY poor translations in some places. I blew many 30A fuses raising the blower all the way up (4") because the stop limit switch wasn't contacted. The wire rope (49 feet!) got pretty mangled forcing itself between the wraps on the next level down. Note that the "support rods" you see in the picture below do not exist in the picture on the Sears site. Also not shown (and I've taken it off so I can't show you either) is a safety plate with a large slot for the cable covering the winch drum. At first I thought the swage that made the loop in the cable was jamming against that. Since it still blew the fuse after I took the safety plate off I figured it was the swage jamming between the cable on the winch and the "support rods". I ordered a 10' lift rope thinking that would let the shaft pivot the extra 1/2".
But NO, it failed in exactly the same way. I don't know if there is some adjustment that needs to be made but for now I Gorilla Taped a 1/2" spacer (spare part not needed on my tractor) to the inside of the plate that is SUPPOSED to hit the limit switch. Tested OK in the barn, will have to see if it is good for hours of blowing snow.
I will say that this blower is much better than the 46" one I had on my old 1995 Yardman. That one was mounted on rails that had to be bolted onto the frame in several places. Which means you had to lift and hold it in place to install it and you couldn't be off even 1/16". It also used two big "helper springs" that weren't all that easy to stretch to attach to the tractor. The pulley bracket that goes under the tractor was also held on by 4 bolts. Not the easiest thing to hold up with one hand while using your other two hands to install the bolts. This new machine has brackets you mount permanently to the tractor frame. Both the under tractor pulley bracket and the blower itself have slotted plates that you slide over pins on these brackets and 2 clevis pins for the other 2 attachment points. Super simple. The "work" is now getting down on the ground to connect the blower belt.
   / Pictures of your snow weapons #2,414
Looks like you did a good job on your blower chute Bruce. It seems like the manufacturer should have made the chute so it would turn farther from the get go. I hope the switch mod you did works when you need it on the job. Did the bracket that holds the weight come with the weight? How much work was cut in mounting the new blower over the older one? All the mods you did will make life much easier for you. Good for you. Keep us updated when you use it to see how it works.
   / Pictures of your snow weapons #2,415
Well no snow yet here in Nova Scotia... but it's gotten pretty cold in the passed couple days... just a matter of time.
I'm ready :)
   / Pictures of your snow weapons #2,416
I sent an email to Agri-fab saying "I have some suggestions to improve the product, do you REALLY make the blower??" after not seeing the blowers on their web site. They make blowers but don't sell them to you and me. They make them for Sears and Husqvarna (which I understand made my Craftsman tractor). The lady said I could send my suggestions so I did. We'll see if future models have a chute that rotates more than 90 degrees. I also had some suggestions related to packaging of parts and the instructions - needed both the printed ones and the videos on the Sears site (beware, the parts aren't numbered/lettered the same in the video as they are in the printed instructions).
The weight kit (not part of the package!) includes the bracket and is "universal" so there are extra parts just as there are with the blower. NONE of the pictures matched the back of my 6 month old tractor. Now that I think of it the reason I had to mount it angled wasn't the holes but the location of the pin you pull to put the transmission in neutral to move the tractor by hand. The picture that looked most like my tractor has that on the lower right, mine is on the upper left and the bracket would be right in front of it making it unusable.
With regard to mounting the blower, after installation on the tractor frame of the "permanent" parts, it is a BREEZE. Even the tensioner for the belts is super easy - a chain runs through a hole in the side of the pulley bracket to a spring inside. To tighten the tension, you pull the "t handle" on the chain and stick a hairclip pin through it. One for the blower belt, one for the PTO belt. The old one required laying on the ground pushing the idler pulleys so you could put the belts around them. With this one I can just loop the belts around the pulleys while sitting and pull the tensioning chains.
Under tractor pulley bracket:
You can mount the blower itself in a few minutes, by yourself ... no strain. Just line the pins on the tractor up with the slots on the blower. Use the chute turning handle as a lever to get the clevis pin on the left side in, the one on the right will be really close and you can put in that pin.
Then connect the blower belt under the tractor, the cable from the winch and the leads for the limit switches. This is another place I had suggested they make a change. When connected there is MAYBE 1/4" of the connector on the tractor side to grip meaning you really have no choice but to pull on the wires, a definite NO-NO!!!! You could try to grip it with needle nose pliers I suppose but there are plenty of connectors out there that are made to come apart easily. This IS something you will do at least twice a year, not like the connectors you never touch buried under the dash of a car for example.
   / Pictures of your snow weapons #2,417
My snow fighter...
6010 HST Mahindra, Fisher Stainless 9.5 Extreme V, and a 8ft Fisher Angle plow if needed. I have the cylinders of the V plumbed together so it only has V, straight, or scoop. After the first pass I scoop everything. I love the backhoe for weight, but would like a blower on the back, I think?
   / Pictures of your snow weapons #2,418
My snow fighter...
   / Pictures of your snow weapons #2,419
Those are nice, Eddie, that Fisher looks pretty solid, what made you buy the V plow?, and what was the price tag on it.
   / Pictures of your snow weapons #2,420
Those Fisher V plows are not cheap. A friend of mine had one installed on his Dodge Ram harness etc and it cost him 8500.00 cd. So the plow alone you are looking at about 4000-5000. My front mount snow blower was about that price.
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
John Deere 6110M (A53317)
John Deere 6110M...
KUBOTA SVL97-2 SKID STEER (A60429)
KUBOTA SVL97-2...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56438)
Neckover GL24-2-7K...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
