Chipper Woodmaxx hydrolac feed problems
/ Woodmaxx hydrolac feed problems #1
Budweiser John
Dewitt, Michigan
New Holland TC45D
Any members out there who own a. Woodmaxx hydrolac feed chipper ever had any problems with the feed rollers not turning?
Woodmaxx thinks it may be the high pressure relief valve is malfunctioning and is sending a replacement. My machine is almost new with probably less than 20 hours total usage.
/ Woodmaxx hydrolac feed problems #2
I have about as many hours and mine works fine.
I assume you have checked fluid levels, water contamination, obvious signs of a foreign object jamming the rollers, and have set the speed to something above minimum? Mine won't turn under about 30% of the max setting. I'm assuming you didn't accidentally bend the safety bar and valve lever.
You don't give a lot of info so I'm just guessing here. I'm assuming you have ruled out the belt to the pump slipping or being loose?
What have you tried and are there any obvious symptoms like unusual noises or vibrations?
/ Woodmaxx hydrolac feed problems #3
December in Michigan. Is water in the hydro fluid a possibility blocking all flow? The cap is well vented, so pressure washing the tank could easily splash water in. Maybe even a heavy rain if its stored outside.
What fluid did you us--the cheapest 8 gallons of hydro fluid that you can find that is thick as molasses in December below freezing, or thinner stuff?
When was the last time you used it? Warm weather?
Thanks for the suggestions. After replacing the high pressure relief valve the unit was still inop so Woodmaxx then suggested, and sent, a new spool valve. Still no progress towards a solution so they are shipping out a whole new pump today.
As far as hydrolac fluid, we filled the unit with the exact recommendation from Woodmaxx and when not in use the unit is stored inside.
The Woodmaxx Chipper is perfect for our use in maintaining fence rows and thinning the wood lot. I must say, Woodmaxx has bent over backwards in their concern and response to our phone calls and sending warranty replacement parts. Looking forward to getting back in the woods.
/ Woodmaxx hydrolac feed problems #6
I have the same unit and ran into a problem like this while chipping last winter. What I figured out is the pump had shifted loosing the drive belt slightly so the pump was not being driven as it should. The pump base has slotted holes with bolts through them. I loosened the bolts and shifted the pump and tightened up the tension on the drive belt. Works as new now.
HP
We investigated that possibility but not the problem. Woodmaxx has shipped out a new pump that should arrive today.
/ Woodmaxx hydrolac feed problems #9
Just in case it helps someone, I had the same problem, and the cause was a clogged hydraulic filter. During the 2 years I've owned the chipper, a few ounces of water had gotten into the hydraulic tank and caused some sludge to build up. After replacing the hydraulic fluid and filter, it runs like new. Woodmaxx ought to include checking the filter in their troubleshooting section. Cheers.
/ Woodmaxx hydrolac feed problems #10
Thank you for your suggestion. I will include it in my manual.:)
/ Woodmaxx hydrolac feed problems #11
Great suggestions or reminders for maintenance checks or areas of concern. What i've noticed from the OP, is that Woodmaxx gives EXCELLENT customer service. I experienced this service myself when we first ran our WM-8H three years ago. The infeed drum was mismanufactured and was out of round, or rather one side of the axle in said drum was off-center causing the assembly to "wobble." WM replaced the drum, no questions asked, with free, next-day shipping. OUTSTANDING!
/ Woodmaxx hydrolac feed problems #12
Been thinking about ordering one later this summer so I am glad to hear they are treating you well.
2023 Tesla Model 3 Sedan (A66738)
2023 Tesla Model 3...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
PORTA POTTY (A68842)
2016 Dodge Charger Sedan (A66738)
2016 Dodge Charger...
2015 CATERPILLAR 525D DUAL ARCH GRAPPLE SKIDDER (A65056)
2015 CATERPILLAR...
2019 KENWORTH T880 TRI-DRIVE HYDROVAC TRK (A67714)
2019 KENWORTH T880...
