Fluney Loader Attachments
/ Fluney Loader Attachments #23
Hey there, can I get a price quote for your 60" root rake grapple, and a set of 48" standard duty pallet forks. I can't find the grapple on your site, but it's posted on the first page here. Both to fit john Deere 3000 series loader. As well as shipping quote to La Crete Alberta. Maybe also just to Edmonton Alberta and I could pick it up there. Thanks! Tried emailing but no reply, so I'll try here!
/ Fluney Loader Attachments #24
Hello,
I have a B7100 Kubota, and need to confirm if it is a level 01, 3 point hitch or a level1 3 point hitch. I me sure a little over 34 inches spread at the draw bar, if this is any indication. I would like to find a Dirt Scoop, and those I have seen are all level 1 , it seems to me a little big, can someone advise me? Thank you in advance.
Norm
/ Fluney Loader Attachments #25
Hello,
Norm
It should be Cat1. Measure the diameter of the hole on the lift arm and check this chart.
Cat 1 dirt scoops are made in different widths, 24" and 30" are the most popular sizes.
/ Fluney Loader Attachments #26
Dear Xfaxman,
thank you so much for the info, I checked, and mesurements matches Cat 1 hitch. Althought the spread on my tractor was a little wider than specs, I think it doesn't matter much anyway. I can at least start shopping with accurate fit.
Best wishes to you and all members in 2015!
Normand
Canada
/ Fluney Loader Attachments #27
Dear Xfaxman,
Normand
Canada
Your'e welcome. If you will be using it a lot, get a hydraulic top link, makes it more better. :D
This is from ten years ago, when I had a tractor. The scoop was 36" wide.
/ Fluney Loader Attachments #28
Est. in 1986. Our Company, Donald Fluney Welding is located in Shelburne, Ontario, Canada. We are your one stop source for your loader attachment needs. We are very confident that you will be very satisfied with the services that we offer.
Some of the services we offer include: Loader Attachment Manufacturing for both Agricultural & Construction. Quick attach systems, bale spears, manure forks, pallet forks, stone forks,loader buckets, grapple buckets, grapple rakes, snow blades and pushers
The information on our website will help you make the most of our services. If you have questions, please don't hesitate to contact us. 1-855-925-5793 or sales@fluneywelding.com
We also offer attractive pricing for top quality workmanship.
Our team at Donald Fluney Welding will be pleased to evaluate your needs. If it is a standard attachment or custom designed and built. We offer you the services that will help you achieve your new goals.
Post any questions or comments here.
Thanks again for your valuable time. We are certain that you will consider Donald Fluney Welding for all your loader attachment needs.
Joe Fluney
1-855-925-5793
Though I live in the US, I have a summer cottage in SHELBURNE, NS.
I have an older Ford TLB with a 40 x24" hoe bucket that I want to get a manual (40"?) thumb for.
The hoe itself is a Ford model 750 which is a 10' hoe, and was used as a cemetery machine
I want a manual thumb that can be pinned up when not in use, and is not any heavier than necessary.
It is possible for me to buy a manual thumb like this, but the jaws are made of 3/4" steel, and that is too heavy to suit me.
I have a set of plans, but would be interested in what you might be able to offer.
Shipping could be either to Shelburne, NS, B0T 1W0, or to Eastham, Ma. ZIP 02651, whichever might be less expensive.
Your response will be appreciated.
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
2008 International 4300 Altec LRV60-E70 70ft Forestry Bucket Truck (A61568)
2008 International...
211297 (A62131)
211297 (A62131)
UNUSED RAYTREE RMDM72S - 72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
