TSO
Elite Member
I think you're right. I think you have to move up to the P7040 to get the hydraulic shuttle.
Or down a touch to the XU6065
I think you explained the differences very well.I'll answer Synchro Shuttle and Hydraulic Shuttle.
Synchro is just like changing gears in a synchronized transmission. It won't grind into gear. But you have to push the clutch to perform this task.
Hydraulic can be changed from forward to reverse with no required clutch pedal action. Acts like a torque convertor. I still use my clutch pedal a lot with Hydraulic Shuttle to control the action or to gently move in a direction. But when out in the open and simply wanting to change direction I just use the shuttle lever and the brakes to stop movement.
I think a Power Shuttle and a Hydraulic Shuttle are the same thing??
My little Ford is Synchro requiring clutch pedal action every time I stop/start/change direction. My Kubota is Hydraulic and only requires clutch pedal action if I want delicate control.
Sorry I can't be more help.
Thanks. That helps clear things up.
Makes you wonder why LS would use a non-power shuttle in the P7010. Can't see any reason other than cost to only have a basic synchro
Not picking on anyone, just making a point.
Why would truck manufacturers offer a pickup truck with a manual transmission??
Point made but who still offers a manual in a full size truck? I haven't seen one in years
According to the LS USA brochure for the P7010C, power shuttle is available. Here's the link to the brochure: http://lstractorusa.com/wp-content/uploads/2013/12/P-Series-Brochure.pdf My best friend has this tractor and it's beast! In many ways, I wish I had got this one instead of my U5020C, but mine does everything I want and has a much smaller frame.
Ground speed PTO can be used with some planters, lime spreaders and to drive the wheels of a forestry trailer, giving you drive to the trailer wheels. Great for wet areas but be real careful turning sharply on the road!
Right.
So if I've got this all straight, Case has options of:
3 stick/foot treadle (no E-hoe)
4 stick/foot treadle (with E-hoe)
Joystick no treadle -- What operates the E-hoe with this one?
I'm not sure this was ever answered completely. If it's a Case with wobble sticks/joysticks, the E-hoe is controlled by a fore/aft treadle pedal that kind of looks like a throttle pedal on the right side of the control tower. If it has pilot controls/excavator controls, the right side grip has buttons to extend and retract the E-hoe.
Yeah, after I posted that I remembered my Boys talking about Dodge not offering manual trans in their heavy diesels anymore.
My neighbor has an '07 diesel dually Dodge with a stick.
P.S. I have syndrome shuttle in my U5020C and I have no issues with it and am not sure I would want HST if it were available. Power shuttle? I think I would have liked that option, but not worried about it at all.
