Mahindra 6110
/ Mahindra 6110 #21
Never ever has it been up to temp on the gauge or hot coolant in the radiator.
Just out of curiosity, cover the front of the tractor with a towel so that no air flows from the front of the tractor through the grill to the radiator. See if it warms up then.
/ Mahindra 6110 #22
Marentette,
I'm aware of the problem and that there is a fix or a workaround. But we do not get very cold here in California and it has been a while since we have had to deal with this. I can't remember what the fix was, partly because early on there were several different "fixes". One involved restricting the bypass with a small ball valve that you closed down in winter. But I think they may have come up with a more "factory" solution after they tested that.
The thermostat controls engine temp, and in theory stays closed until it reaches a set number, let's guess that is 180 degrees. Unless you are in extreme weather (think well below zero), the engine should run no colder than the thermostat designation. But like most vehicles, there is a bypass that allows some coolant to go around the thermostat. On these engines, the bypass is big enough and the radiator big enough that the small amount bypassing cools the engine down below 180. On a normal day working the tractor like pulling a disc or mowing with a decent size mower, it will get to temp. But a cold day with a light duty job means it over cools and never warms up. While it is better than overheating, it really is best for a diesel to get up to temp and not run around cold.
I am sure the dealers and the service reps in the cold country have a solution. Any other dealers chime in?
If you totally strike out, I can contact MUSA and try to get the approved fix....if there is an official one.
/ Mahindra 6110 #24
Mtn ranch, i could block air flow to the radiator and it would warm up faster. But it was not designed that way. Hard use in 90 deg weather did not warm it up.
/ Mahindra 6110 #25
OK, I found the TSB. TYM10-AC/62/10/2012 is the number, best to contact your dealer. It is a re-route of the cooling hoses, and it appears to eliminate one of the bypasses. There are a few parts needed, and some specific ways they want it re-routed. Then apparently you then get a warm cab.
I'm not authorized to post an internal dealer TSB on the web, but with the number I gave above your dealer can pull it up on the Mahindra dealer portal and take it from there. I think it applies to 5010/6010 and 6110 cab models.
Hope this helps.
/ Mahindra 6110 #26
I understand that it was not designed to operate like that. :eek: I have seen machines before that needed no fan. If it was as easy as removing the fan and everything was fine, would that not be an easy fix and it would give you more power. A lot of semi trucks block the radiators all the time in the winter.
Just a suggestion to try was all. Never intended that you would have to have it like that all the time, any of the time for that matter.
Sounds like you are willing to wait for a dealer to take care of the problem, hope that happens soon for you.
Good luck.
/ Mahindra 6110 #27
Thank you Dave, when i call to make the appointment i will forward that tsb number so they can have the parts on hand. My block heater is open circuit and two remotes are not yet installed. I have 77 hours on my machine from new. They are good guys, but also run a full fledged very busy diesel repair shop. The mahindra dealer was added a few years ago. One of the things i negotiated into the purchase was pickup and delivery for warranty work as I do not have a trailer capable of moving the machine. I like to have my ducks in a row before service. I own and operate an auto repair facility and the parts are here before the vehicle is scheduled for service. Diagnosis is one thing, don't mind doing it myself, when i have time. The machine is integral to my business, as it is winter, and i have already sold my snow blower. Less down time is key.
/ Mahindra 6110 #28
Brian, I did not mean to insult you. I get enough heat to stay warm, but after a long time, this issue will cause wear. I am familiar with engines and cold weather. Care to quote me a top and tilt kit for my tractor? Also, does your third function FEL diverter come in a kit for my tractor?
/ Mahindra 6110 #29
Part of the problem with forums when we assume things and simply do not know the rest of the story. I had no idea that you had a newer tractor.
As far as a quote for items for your tractor, best to fill out the contact page and we can go from there. ;)
2015 Komatsu PC360LCLC-10 Hydraulic Excavator (A60352)
2015 Komatsu...
2026 Steel Pines Cargo 8.5x20 Enclosed Trailer, VIN#7FWBE2021T1037982 (A61166)
2026 Steel Pines...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
2022 CATERPILLAR 310 EXCAVATOR (A62129)
2022 CATERPILLAR...
LandHonor LHR-G209 Anchor Shackle Set (A60352)
LandHonor LHR-G209...
(3) 9.5L-15SL Wheels (A62177)
(3) 9.5L-15SL...
