Hook like attachment for holding top link up when not in use.
   / Hook like attachment for holding top link up when not in use. #12
How good are those tool cats??.
Very good! :D 4 wheel drive, 4 wheel steer, 4 wheel independent suspension, 61 horse power turbocharged Kubota 3 cylinder diesel. SSQA with aux hydraulics on the lift arms. Check my threads in the Toolcat Forum for more pictures: http://www.tractorbynet.com/forums/toolcat/
Very good on sidehills with the 7' brush hog. :thumbsup:
   / Hook like attachment for holding top link up when not in use. #13
I keep a separate top link on each implement so I don't need to adjust them or have one protruding from the back of the tractor. My DK35 came with a hook but I don't use it.
Perhaps you could use some eye bolt and cable arrangement to support the top link. Here is a photo of one I use to support my finishing mower drive shaft:
   / Hook like attachment for holding top link up when not in use. #14
I have a coil of 1/8" wire laying around the barn and just used a length of that to loop through a hole in a bracket on the ROPS, then bent the other end into a hook to hold the top link. I might take that off when I get a QH.
   / Hook like attachment for holding top link up when not in use. #15
A tarp strap works better than a bungee cord.
   / Hook like attachment for holding top link up when not in use. #16
Mine came with the hook... but once the hydraulic top cylinder was installed that hook was way too small.
Need to fab up something. Someday. I mostly have the backhoe on, so simply remove the top link.
   / Hook like attachment for holding top link up when not in use. #17
Hook a tarp strap to the OEM hook.
   / Hook like attachment for holding top link up when not in use. #18
I carry a couple of spare bungee cords hooked across the ROPS. Also use them to support the top link,
(2) Firestone 380/85R30 Tires w/Rims (A56469)
(2) Firestone...
John Deere 6120E (A50323)
John Deere 6120E...
2018 ford fusion (A56859)
2018 ford fusion...
2016 Ram 5500 Enclosed Service Truck (A52377)
2016 Ram 5500...
DIRT DOG CBX60 60' BOX BLADE (A57192)
DIRT DOG CBX60 60'...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
