Exhaust extension
/ Exhaust extension #1
orwell
orwell,ny
X748
Does anyone know of exhaust extensions available for my X748 ? The exhaust exits directly onto hydraulic hoses from the snowblower.
/ Exhaust extension #2
JD sells wire loops that bolt to the tractor. I put one on mine near the front using the hood pivot bolt, and it keeps the hoses out of the exhaust. I would look to go this route before extending the exhaust.
/ Exhaust extension
Yes my tractor came new with this loop which puts my hoses right in front of exhaust.
/ Exhaust extension #4
Move the loop or add another. Mine is not in the recommended location.
/ Exhaust extension #5
The setup person at your dealer didn't take the exhaust into account, so you will likely want to do that job for him (and move it as Gittyup said).
Don't think you will want to add an exhaust extension.
I would mention it to the dealer that set it up, so they are aware of the problem. Otherwise there will be no feedback to the setup kid. (and not too long ago I was that "kid" setting things up).
/ Exhaust extension
Thanks guys for the feed back. I'll take a look at this as soon as I have a few minutes.
/ Exhaust extension #7
Here is my setup. Since taking the photos I've added a coupe of tie wraps to tiddy things up a bit. Hoses have been good thus far, staying above the exhaust. I know what I have is for the blade, and a retro-blade fit at that, and you have a blower. Might be a bit different, but there should be plenty of places to dress the hoses to prevent exhaust damage. IMG_0066a.jpg
/ Exhaust extension #8
Here is my setup. Since taking the photos I've added a coupe of tie wraps to tiddy things up a bit. Hoses have been good thus far, staying above the exhaust. I know what I have is for the blade, and a retro-blade fit at that, and you have a blower. Might be a bit different, but there should be plenty of places to dress the hoses to prevent exhaust damage.<img src="http://www.tractorbynet.com/forums/files/john-deere-lawn-garden/402816-exhaust-extension-img_0066a-jpg"/>
Hey Gittyup, is it just me, or does your plow mounting frame in the right side of that pic have an enormous crack in it? Sure looks like it. I'd be welding/reinforcing that ASAP if it were my machine.
/ Exhaust extension #9
That's water or oil running down the side. Sure does look like a big crack at first glance!
/ Exhaust extension #10
Here's where the hose hangers should be located, one of them just above the exhaust. Installed per JD front hitch installation instructions.
These photos show the location without the hoses, you can see the wire loop is attached to a hole in the frame just above the exhaust:
/ Exhaust extension #11
I don't know, I swear I can see through it. I'm voting it's a serious crack. I would think the rod would fit closely in the cutout. As it sits, there's 1/4" of clearance on either side of it, with a 1/2" crack traveling down.
/ Exhaust extension #13
If you can expand on the pic, it looks more like water than a crack. If it is a crack, he's got issues....
Not cracks anywhere. It's melting ice, dirt, and just old (1994) with original paint. But there is nothing that affects it's function or strength. One of these days I may paint it.... but then again, why?
/ Exhaust extension #14
Your JOHN DEERE is show room brand new. ( beautiful )
/ Exhaust extension #15
Here's my set up.....hoses aren't that close to exaust....wonder if you could route your hoses over the higher bar on the hitch....I might be able to do that too.
/ Exhaust extension #16
Rerouting the hoses is the best way. Adding an extension to the exhaust may cause damage by vibration to your muffler or pipes by the extra length, particularly if it is unsupported. How the hoses are attached at the hydraulic valve greatly affects their effective length, lay and positioning.
/ Exhaust extension
I bent the wire loop up a little & rerouted hoses, they are above exhaust now.
Thanks for the feed back.
2022 Magni TH5 5.19P (A63118)
2022 Magni TH5...
2015 GENIE S-65 MAN LIFT (A63569)
2015 GENIE S-65...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
2013 John Deere 8360RT Track Tractor (A63109)
2013 John Deere...
2002 John Deere 4510 Tractor (A64047)
2002 John Deere...
