seat adjustment on GX345 ?
   / seat adjustment on GX345 ? #1
Rebs
Niagara Falls, NY
JD 175
If the seat all the way back isn't quite enough, is there a way to get it to move back a little further ?
Is it possible to drill new seat mounting holes ?
   / seat adjustment on GX345 ? #2
Don't know why not ----- you could most likely get an extra couple of inches with new mount holes. You'll need to remove the rear deck.
   / seat adjustment on GX345 ? #3
I have a different tractor, but what I did was make new mounting brackets out of aluminum angle. The brackets bolt into the tractor using the existing bolts. The seat then bolts further back on the brackets. I moved my seat 2 inches up and 2.5 inches back. I'm 6'3" and I have never sat on a tractor as comfortable as this one is now that I moved the seat. However, If anyone were even a smigget shorter than me, there feet wouldn't even reach the floor now!
View attachment 403038View attachment 403039
Thank you for the reply with the pics. I believe that will work on my JD
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56436)
PENDING SELLER...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2003 Caterpillar RM-250C Reclaimer Mixer (A55973)
2003 Caterpillar...
2016 SERCO 8500 KNUCKLEBOOM LOADER (A58018)
2016 SERCO 8500...
JEEP FOR DOUBLE TRAILER (A58214)
JEEP FOR DOUBLE...
