Solar Batter Tenders
/ Solar Batter Tenders #1
Indygunworks
Indianapolis, IN
1980 Ford 340
So my property is 30 minutes away from me. We are building, but I don't know when I will be able to run power to the barn where its stored that's about 200 feet from where the house is going. its a 24x32 barn, and the tractor is parked on the front of the 32 foot long side. the back of the 32 foot side is facing south which is where I would probably need to mount the solar panel. I would need around 40 feet of cord to comfortably hook up the tractor and be able to run the wiring so its out of the way. So far every time I have gone out the tractor has not started, this is every couple weeks or so. I have to pull my truck in and jump start it every time which is getting old, and once we live out there I would really like to be able to just open the barn door and use it. A portable jumper box doesn't have enough cranking amps to help any, but as soon as its hooked up to the truck she turns right over, even in the cold.
Any reccomendations for a solar charger? What about one that could possibly tend a 4 wheeler batter as well?
/ Solar Batter Tenders #2
How about a new battery?
battery was brand new 1.5 years ago, and wasn't cheap. Its a positive ground system and I think I have a small short somewhere that slowly drains the battery. Every now and then she will fire right up even after a week or two of sitting, but for the most part she is normally dead when I go out there. Not dead dead, she will try to turn over and spit some smoke out, just not enough to really get it turning to start. More of an issue in the winter than the summer.
/ Solar Batter Tenders #5
I bought a cheap HF solar battery tender and it caused my fully charged battery to go dead overnight. I took it back and they said yeah, they don't work well on full sized batteries. Mainly motorcycles and lawn mowers. I do use a cheap 115v battery tender on my plow truck and it works perfectly.
Anything that has to plug in is DEFINATELY out of the question. Do they make quick disconnects for the battery terminals? Maybe if I could just throw a switch or something to disconnect the battery it wouldn't be able to drain down at all.
/ Solar Batter Tenders #7
I agree easiest way is to just put a disconnect or unhook a terminal off the battery. Being positive ground I'm guessing your running a 6V battery which always seem to be stubborn in the winter anyways.
For what it's worth I have used one of those cheap solar chargers that you put the gator clips on the battery terminals on my oliver for long term storage 3+ months. Every time I went out there after sitting for months even in the dead of winter it has started right up.
Its a 12v system. I really don't think the battery is bad. I think I just have a very small short somewhere that pulls just enough of a draw that over a few weeks time takes away enough of the cranking amps that it just doesn't have enough UMPH in the cold weather to get her going.
I like the economy battery switch there. Would there be any big box type stores that I might have locally to pick up something like that?
/ Solar Batter Tenders #10
Battery disconnect and a solar charger. There are simple cheap disconnects. Check your local auto parts store.
Also, with a positive ground system. which terminal do I hook the disconnect up to? How do I tell if its a positive ground system as well. I am not 100 percent sure on that but would like to know for sure.
/ Solar Batter Tenders #15
Really doesn't matter, you are breaking the circuit either way. Which ever way it is easier/safer to install.
/ Solar Batter Tenders #16
The switch you linked to that attaches directly to the battery works ok but not for very long. I would just disconnect either terminal and leave it off. On any direct current system it s safer to work on the grounded side first ,follow the cables see where they end up ...Trevor
I REALLY REALLY don't want to mess around w/ disconnecting it from the post every time. Why would it not work for very long? And which one? I linked to several.
See where they end up? So on a positive ground, the positive cable should be hooked up to the frame somewhere correct? But if the neg terminal leads to the frame then its a normal system?
/ Solar Batter Tenders #20
I've used a 15watt solar panel on my skid steer without any problems. Also have a 5 watt panel on my 25ft trailer for the winch. Both batteries are full size. Trailer is a deep cycle and skid steer is a start battery. Finally after 5 years I have to replace the deep cycle battery.
2013 FREIGHTLINER Cascadia (A63118)
2013 FREIGHTLINER...
BUNDLE OF (3) 3'X17' PANELS (A62131)
BUNDLE OF (3)...
2017 Unverferth 1245R-35 Rolling Harrow (A63116)
2017 Unverferth...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
UNUSED RAYTREE RJSG30-30" TRANSVERSE STUMP GRINDER (A62131)
UNUSED RAYTREE...
