Cab, 12x12 shuttle and self-leveling loader?
/ Cab, 12x12 shuttle and self-leveling loader? #1
CDN Farm Boy
Ottawa Ontario
Kubota B3300SU
With it being Christmas, I figure that it's a good time to dream about my next tractor, not that I have any complaints with my B3300. My wife often talks about getting another dog (we already have 3) and my response is sure, when I get to have a second tractor......
Must have list:
Factory cab
12x12 shuttle trans (or greater, just don't want a 9x9)
Mechanical self-leveling loader with decent lift capacity
Aftermarket loaders are acceptable and easy to add to a good tractor that doesn't have one
Not likely new but don't want ancient either
Brand not really important but JD has a slight edge
As small as I can find meeting the above criteria.
Opinions?
/ Cab, 12x12 shuttle and self-leveling loader? #2
With it being Christmas, I figure that it's a good time to dream about my next tractor, not that I have any complaints with my B3300. My wife often talks about getting another dog (we already have 3) and my response is sure, when I get to have a second tractor...... Must have list: Factory cab 12x12 shuttle trans (or greater, just don't want a 9x9) Mechanical self-leveling loader with decent lift capacity Aftermarket loaders are acceptable and easy to add to a good tractor that doesn't have one Not likely new but don't want ancient either Brand not really important but JD has a slight edge As small as I can find meeting the above criteria. Opinions?
If you're keeping the 3300 why get the new one as small possible?
/ Cab, 12x12 shuttle and self-leveling loader? #3
I sometimes think it's a harder decision to buy a second tractor than it is the first.
For me, I'm always a little paranoid about buying too small. And, it's only in my fantasy dreams that I can think of a cab. My uses just won't allow it.
For a used, older model tractor, parts availability becomes very important.
Were I you, I'd be looking for a tractor to fill the gaps that your current tractor has.
Keep us posted on your progress!!!
/ Cab, 12x12 shuttle and self-leveling loader? #4
Must have list:
Factory cab
Opinions?
What are the uses for the new tractor?
When you say "decent loader" what do you mean? 1000lbs? 2000? That's gonna size the tractor for you. Also, a self leveling loader typically doesn't come until you're up around 50hp+ and I think JD is the only one (the 400cx on the 4x20 series vines to mind) in the "compact" range with a self leveling loader option.
Why only shuttle? Have you considered HST? If not, what are the reasons?
Why does JD have a slight edge?
Finally, what is your budget?
/ Cab, 12x12 shuttle and self-leveling loader? #5
Have you ever used a mechanical leveling loader? We hated ours and disabled it, much happier with a standard one, wouldn't mind having one with the option, but certainly not full time.
Snow and firewood/bush work mostly would be the uses. Easy to find tractors in the 80 hp range but I don't want something that big for in the bush.
Since the 3300 is (obviously) 33 HP, this one needs to be enough bigger to justify keeping them both.
Something in the 2000 lbs of lift (or more?) since I have no plans of the 3300 going anywhere, it already has 1000 lbs of lift.
I've never used hst in anything bigger than my 3300. Used shuttle lots and like it. I like the shuttle for long stretches of snow and that they put power to the ground better.
Budget? Lol. I usually work the other way. Figure out exactly what I want then how to pay for it. Realistically, as cheap as I can....just like everything else.
It's been nearly 20 yrs since I spent any significant using self-leveling. I spend so much of my time with the loader just moving stuff around and constantly adjusting the bucket to keep things level. I'm actually considering building one for the 3300 just to see.
JD has a slightly edge just cause I like them best but not so much that I won't consider other brands. Not willing to pay a premium for it
/ Cab, 12x12 shuttle and self-leveling loader? #7
Shuttles are good for ground engaging, but if you're doing mainly firewood and loader work, HST is better. I would personally prefer hat over shuttle for brushing, or any meeting, as well. But, shuttle will give you a wider range to choose from.
What size brush-hog do you want to use?
/ Cab, 12x12 shuttle and self-leveling loader? #8
I would get a hydraulic shuttle. What model deere are you leaning toward? Any other brands that are ruled out or is the field open? Sounds like something around 60 hp would fit your requirements.
Field is open to any of the major brands. Pretty set on the Shuttle trans. In the last 5 yrs I've got in the range of 100,000 shifts doing snow removal so I'm quite comfortable with it
Bush hog will stay on the 3300 for better maneuverability.
TripleR, what is it that you didn't like about the self-leveling?
/ Cab, 12x12 shuttle and self-leveling loader? #10
We use our loaders mostly for moving dirt, rock, brush and our farms have a lot of hills. The self leveling bucket cut the amount of dirt or rock we could move as we needed to roll the bucket back going down hill and forward going up hill, some distance may be a half mile or more and we would lose a lot of material. Same thing hauling logs etc on the forks, we needed to be able to have more roll/dump control.
/ Cab, 12x12 shuttle and self-leveling loader? #11
Have you looked at a hydraulic self leveling loader. I know Kubota uses them on the m9960 sized machines instead of a mechanical. I am like you I prefer a self leveling loader over a regular one. But I use my loader to move and unload hay trailers, stack a lot of manure and load trucks. I always found that going up and down hills I had to adjust the angle on what ever type of loader I had. Self leveling just helps speed up processes when you don't want to dump the loader contents back on you.
/ Cab, 12x12 shuttle and self-leveling loader? #12
You can still adjust a self leveling bucket the full range of motion and tilt it back or forward to adjust for uneven ground. Lifting a full bucket of material without a self leveling bucket can cause the material to spill off towards the tractor.
/ Cab, 12x12 shuttle and self-leveling loader? #13
With as much experience as you seem to have, I can't fathom why you need sometime here to tell you what size tractor you need. Once you figure that out, I'm sure it will be easier for people to offer advice on which tractor to go with.
And I'm still unclear on what the tractor will be used for. Originally you said brush work, but then said you're keeping the brush-hog on the other tractor... ?
If it's going to just be bucket work moving wood around, why not get an articulating wheel loader instead?
/ Cab, 12x12 shuttle and self-leveling loader? #14
I've always wondered about that. At first glance you'd think that's very cool. But like you said, most times it would be inconvenient. At least for what I do. Repeat tasks like carrying big bales would be a use where it would be handy. I believe Kubota's is selectable?? I see several JD systems here that are mechanical.
/ Cab, 12x12 shuttle and self-leveling loader? #15
There was no way to adjust ours satisfactorily on our Westendorf, if so we wouldn't have removed it.
Yes, you do have to mind lifting a full load to keep it from spilling, but we were use to that on our other tractors and it wasn't a problem on them or the other seven tractors we have with a standard FEL; we only had to make that mistake a couple of times many years ago while using the old two lever loaders.:)
/ Cab, 12x12 shuttle and self-leveling loader? #16
Yeah, I considered the selectable one on our 8540, but we don't do any hay and very little pallet work, so it wasn't worth the cost for us. With the way things have been going, I would just forget if it was on or not and dump something on my hood.:laughing::eek:
/ Cab, 12x12 shuttle and self-leveling loader? #17
Didn't know that Kubota's was selectable. That does change things.
/ Cab, 12x12 shuttle and self-leveling loader? #18
I think hydraulic, self leveling is only available on the M Series and up; may be wrong, but didn't see it on their build site..
I'd said bush work...not bushhog. Felling trees, skidding logs etc. Articulated loader won't run the snowblower.
I know what I want for features and looking for input as to which models will fit that without looking thru specs of 200 different machines available new or even more of the non-current used market. Nowhere did I say anything to the sort of questions often posed here of "I just bought xx numbers of acres and am looking for my first tractor..."
I figured with the number of members there are here, there would be some help in narrowing my search. As I said earlier, I know what I want for features, colour and HP number are less important.
/ Cab, 12x12 shuttle and self-leveling loader? #20
I'm just trying to find a way to narrow down your search... This "snowblower" info is new information, it wasn't in your original post. Also, saying "brush work" is much more vague than "felling trees, skidding logs, etc"... most folks on here hear "brush work" and assume you're talking about clearing light brush, etc.
Here's your original post:
Must have list:
Factory cab
Opinions?
So, from what you're saying now, you want a tractor with Cab, Shuttle-Shift, self-leveling loader that lifts 2,000+ lbs, that can have anywhere from 33 - to - 80 HP (as long as it runs a snow blower)... and budget doesn't matter, though you want it to be "as cheap" as you can find...?
Now we're getting somewhere, though that's still a hefty range. For someone that's got like 8-billion shuttle shifts under his belt, I would imagine that you have a fair handle on machine size & strength. Can you narrow things down a bit more? Does the tractor have to fall under a certain weight for trailering, or for operating in certain conditions? For the size snow-blower you're talking about, is there a certain HP requirement you need to have (ie, what size blower do you plan to use)? Do you want the loader to be just over 2000lbs, or will you need more? My loader is rated for a bit over 2500 @ the pins to full height... but sometimes I could use a little more, sometimes I could use a LOT more. I mean, you can technically do the work you're talking about with the small tractor you have now, but how much drastic of a change are you wanting? Help us help you :thumbsup:
UNUSED RAYTREE AMBD72S-72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
2009 Ford F-150 Pickup Truck, VIN # 1FTRF12W99KB57427 (A61165)
2009 Ford F-150...
2024 Schulte 5026 Batwing Rotary Cutter (A63118)
2024 Schulte 5026...
UNUSED CFG INDUSTRIAL MX12RX MINI EXCAVATOR (A62130)
UNUSED CFG...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
