Loader DK 35 FEL Control lever broke!
/ DK 35 FEL Control lever broke! #1
n1wjr
Member
GRANTHAM,N.H.
KIOTI DK 35
I was moving snow today with my DK 35 and went to rise the boom on the FEL And the control lever went all the way down and broke.
I took the boot off and the valve that goes in the valve bank broke off!
it say's something in the Man. about not a serviceable part so probably I will have to buy the whole valve bank,,,,,sound's expensive !
I am heading to my dealer in the morning to see what he has for parts.
just wondering if this has happened to other dk 35 owners with the 1450 loader?
thanks
matt
The problem is all fixed!
Thanks to my wonderful Dealer Upper Valley Equipment !!
They Drilled it out then used an easyout tool to remove the broken piece and
then They fixed it with a new part they had in Stock!
No Charge !!!
And then Dave Said Merry Christmas too me !
Thanks Dave ! and Merry Christmas too you and the Guy's!
Matt smith
/ DK 35 FEL Control lever broke! #3
It's good to see another good Kioti story My dealer is a great guy too (knock on wood )all i have bought is oil and filters . 250 hrs on my dk35 it is used year around and not a problem yet . Wish i had a cab though !!
/ DK 35 FEL Control lever broke! #4
thanks
matt
My loader also broke (2006 DK35), it wont curl down and if I push the lever over to far it curls up instead. I dont have a dealer local so any help you guys can give me would be greatly appreciated.
/ DK 35 FEL Control lever broke! #5
This thread is almost 4 years old, so I'm thinking you may get somewhat limited responses.
/ DK 35 FEL Control lever broke! #6
Probably just a linkage issue. The mechanism in the joystick is fairly simple. You can get replacements online or thru any tractor store. It's not a Kioti-specific thing.
If the bucket is doing anything when you move the lever it's probably not the loader valve
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
golf cart (A56859)
golf cart (A56859)
2020 Broyhill Load and Pack TD3.6 Mini Articulated Garbage Truck (A59230)
2020 Broyhill Load...
