Calling all 1991 1120, 1130, 1140 Owners
   / Calling all 1991 1120, 1130, 1140 Owners #1
crabhab
Member
MD
Kubota BX 2370-1
I am calling all of the 1992 Case 1100 series tractor owners.
I just picked up a 1130 a month ago from a John Deere dealer in Cecilton , MD. I also bought an original Case Three ring binder shop manual and original sales brochure. These tractors seem to be an obscure made by Mitsubishi and sold by case ih tractor offered only in 1991 but, they carried on for years as Cub Cadet 7000 series in the 1990's and even as Mahindra tractors present day. Please share any info and or experiences you have with the Case IH, 1100, Cub Cadet 7000 or Mahindra series tractos.
Here is my new to me tractor skidding dead logs.
   / Calling all 1991 1120, 1130, 1140 Owners #2
I recently acquired an 1130 as well. I have the loader, belly mower and snow blower attachments. I'm currently having an issue with it overheating and would appreciate any info regarding parts for this tractor, especially if there is a Cub model that uses the same parts as I understand Cub bought this line out from Case.
As far as troubleshooting my overheating I've drained the coolant found that my thermostat was completely missing from the tractor. I got a replacement and when filling the coolant it only took about 2 quarts if that. It should take 5.6. I ran it for about 15 minutes and checked the levels thinking that it would work any air bubbles out and I'd be able to fill it more. Well the level hadn't dropped. At this point I'm assuming the water pump is bad and not circulating coolant and therefore not getting the air out of the system. Tomorrow I'm going to take the pump off and see what it looks like.
Thanks!
Sounds like you may have a clogged radiator. I would try flushing it out and maybe a radiator shop can flow test it or boil it out.
   / Calling all 1991 1120, 1130, 1140 Owners #4
Looking for the belt # on the belly mower for an M160 deck. Anyone?
   / Calling all 1991 1120, 1130, 1140 Owners #5
I'm 99% sure its actually a Woods brand mower. I had a **** of a time finding a belt for mine until I figured that out. I can't remember the # though.
   / Calling all 1991 1120, 1130, 1140 Owners #6
I recently purchased a Case IH 1130 that wasn't ran all summer because the previous owner didn't want to replace an axle seal. My question is, it is a hydrostat and I am wanting to pull it up on my trailer to take it home. Is there a release for the hydrostat for free wheeler. Previous owner never had to pull it and has know idea or owners manual. Any info appreciated. I don't want to make a simple fix complicated.
If it is not in a range low med or high then it can be rolled in neutral
   / Calling all 1991 1120, 1130, 1140 Owners #8
I've owned an 1130 since 1991 bought new ( 4x4 hydro static ) great little tractor until you need parts. No injection pumps or hydraulic pumps case quit making them in 2001. A dealer found me a hydraulic pump for $950 plus shipping but I was fortunate enough to find a machinist that could make the gears. It has 3700 hrs. on it and until the last yr. very little went wrong I couldn't fix. Just a heads up for 1130 owners.
Many parts can be had at your cub cadet dealer. The cub cadets of the 90s and early 2000s match the 1120.1130,1140 series case IH tractors from 1991
   / Calling all 1991 1120, 1130, 1140 Owners #10
I believe the Cub Cadet 7232 is essentially the exact same tractor as the 1130. I've ordered a couple parts for my 1130 by searching for the 7232 and they are the same. I also think I read somewhere that the Mahindra 2615 is the same although you might want to double check that.
2015 Ford Fusion Sedan (A55853)
2015 Ford Fusion...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
2010 Nissan Rogue SUV (A53424)
2010 Nissan Rogue...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2015 Peterbilt 320...
1981 JOHN DEERE 570A MOTORGRADER (A52707)
1981 JOHN DEERE...
Alligator Statue (A55853)
Alligator Statue...
