4 point backhoe B2650 ????
/ 4 point backhoe B2650 ???? #1
gixxergary
Member
Elkhorn Wi
kubota
In a few days, I will receive my new, and first tractor from the dealer. Pics will come when it shows up. Its the B2650 with loader and bh77 backhoe. The dealer was waiting for the 4 point mount to show, before they bring it out to me. My question is, I know this is a 3 point mounted backhoe, and that is not ideal from what I read, but what exactly is the 4th point????? Is this the subframe mount that I keep reading about?? If anyone could shed some light on this, that would be great!!!
Thanks in advance,
After a ton of searching, I just found a pic of the "4 point mount". It appears that yes, this is a subframe mount, that stays with the tractor, and there are 4 points to mount the backhoe to that. I was confused by the salesman stating that it was a 3 point mounted attachment and they " ADDED " a 4th point for stability. Yep, that makes no sense. Hoping to see this machine tomorrow, as I have some drain tile issues to fix right away.
/ 4 point backhoe B2650 ???? #4
I assume you have the TLB by now...I'm considering ordering a BH77 for my B2650 HSDC and am interested in your opinion on the hoe.
Only used the backhoe on a 40 foot long trench for a drain tile that collapsed. Ground was frozen, and I would say a 6" frost line. Although this is my first backhoe, I was thoroughly impressed with how much power it had. Made very quick work of the project, leaving me wanting to spend more time digging crap up!!! The only issue I have with the backhoe, is not really the backhoes fault, its the god awful seat on the tractor. Having to get off, reach in to unlatch the seat, turn it around, climb back on the tractor to move, and them re do the seat. In hindsight, I would have got the backhoe with the seat attached. More money, but it really does become a bother. Im perfectly happy, other than the seat, with the 2650. Its the perfect combo of power and size, for me at least.
/ 4 point backhoe B2650 ???? #6
Agree. The seat is a pain. Many times I'll reposition my tab by leaving the seat in the bh position and move the tractor by standing at the controls. One guy on here used a stick to engage the hst and move the tractor.
/ 4 point backhoe B2650 ???? #7
Yup. The seat is a pain, Worse in cold weather, because you have the parka to get caught on the controls. I would like more info on using the backhoe during frozen conditions. I want to clean out some cattails.
/ 4 point backhoe B2650 ???? #8
So is it possible to put the cab backhoe on the non-cab models?
/ 4 point backhoe B2650 ???? #9
The B26XX backhoes are frame mount. Not so easy to remove/attach. I always need help. This summer, I added a cement apron to the barn. A flat surface does make it easier. Of course, I guess there are adapters for anything...if you can afford and justify the cost. But I am not sure the B26 has enough guts to make it worthwhile - I would be very cautious . For the kind of work I do - anyway.
/ 4 point backhoe B2650 ???? #10
If that is what your salesman told you, he should probably sell something else besides tractors. The lack of product knowledge of some equipment sales people used to surprise me.
As far as the BH seat, if you had the separate seat you would still have to get off one seat to go to the other. I do not find the swivel seat you have inconvenient. It keeps the BH a little closer to the tractor and I can reach around to any of the tractor controls. That would be more difficult with a separate seat style.
Either one is better than a shovel!
The best solution are dedicated TLB's you can step thru and swivel in position.
Enjoy your new machine...they are nice!
/ 4 point backhoe B2650 ???? #11
I'm not sure how your 2650 compares in size to my 3300 but I love my BH77. The 2650 is a bit smaller frame no?
I'm lucky to break thru 4" of frost with mine but soil types will have a lot to do with that. The single seat setup is WAY nicer in my mind than the dual setup of some other brands. As Tompet said, you can reach up to the tractor controls (key, throttle, steering, bucket) much easier than on a dual seat. Similarly, from facing forward, you can reach back to the BH controls if you need to.
As far as spinning the seat around or using a stick on the HST pedal to move the machine to continue digging, those are the two WORST ways to do it. Watch a pro for 5 min and you will quickly realize there is a better way to do it:
Put trans in Neutral after initial positioning.
Dig what you can until you need to move.
Crowd both the boom and stick and put the bucket on the ground.
Steer as needed by reaching around behind you to the wheel.
Lift the stabilizers a bit and lift the FEL.
Push away from you with the BH moving the whole machine forward.
Put FEL and stabilizers back down and resume digging.
Repeat.
You should be able to move exactly the right amount to dig as much as you can in every move. You will quickly realize how much more productive it is this way, even when you aren't on the clock for someone. I've done a 150 ft hydro trench and a 100 ft drainage tile around trees & corners and stripped sod off an irregular area of roughly 50x70 with never leaving the BH controls. Forward, backwards, sideways, it's all possible by using the BH
/ 4 point backhoe B2650 ???? #12
The reason I'd like the separate seat model is I wouldn't have a huge amount of hours to put on a BH, definitely more so in forward facing work. I'd rather not lose the nicer suspension seat for the more solid mount. It's handy to swivel, dad has it on his BX, but this seat is such an upgrade in my opinion for loader work that I'd rather not lose it.
/ 4 point backhoe B2650 ???? #13
Now I hadn't thought about having a nicer front seat as a possiblity with dual seats. When I was shopping, all of the 3300s at my dealer already had a BH mounted so it never even occurred to me. Isn't the 2650 more of a deluxe model to begin with which would get you that nicer seat?
/ 4 point backhoe B2650 ???? #14
Ya the 2650 and 3350 have the suspension seat, but that get's removed as I understand when you get the BH. Unless of course if you're allowed to get the cab model BH instead. I don't think the other B's have the suspension seat.
2018 CATERPILLAR 320 EXCAVATOR (A62129)
2018 CATERPILLAR...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2020 Takeuchi TL8R2 (A64126)
2020 Takeuchi...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
