s219
Super Member
- Joined
- Dec 7, 2011
- Messages
- 8,607
- Location
- Virginia USA
- Tractor
- Kubota L3200, Deere X380, Kubota RTV-X
I normally have put the "j" anchors in wet, but it's a pain. Around here, people use a double bottom plate -- sort of. For a 2x4 wall, we put a treated 2x6 down and bolt it in place with the anchors (for a shortcut, I like to rest the 2x6 on the anchors, all lined up, then tap with a hammer over each anchor to mark where the holes get drilled). Then the 2x4 wall and its bottom plate get nailed to that 2x6. Standard practice is to notch the bottom 2x4 plate to miss the anchors (often done shoddily) but I instead drill a hole with a chisel bit so it pokes through cleanly.
Obviously a lot of hassle. I always wondered why this was done versus drilling and placing anchors afterwards, and learned it's because the anchor bolts are on the checklist for the foundation/footing inspection, at least in my county. You can't even move onto framing unless you have the foundation/footing paperwork. So that means anchors put in ahead of time, and all the headaches that brings. I think you're taking a better approach Eddie.
