B3300su rear axle vent tube
   / B3300su rear axle vent tube #1
dtherrien
Central Ma.
B3300su
Hi,
I have a small leak on the right side of the rear axle. It has become worst over the last two months. Not that it leaks alot but i want to fix it this winter.
I started to look for the vent tube to see if it is plugged up but cant find it, or even if it has one.
Does anybody know if it does.
I know the filler cap/plug doesnt fit tight so am thinking that is where it breathes??
Also how big of a job to pull the axle.
I know i will have to remove the backhoe and sub-frame.
Thanks
   / B3300su rear axle vent tube #2
If it's like other Kubotas, it will be a hook shaped tube (like the top of a cane) with a hole in it. I have seen them on the back upper surface of the rear case, and under the seat.
   / B3300su rear axle vent tube #3
My B3200 has the vent in the filler cap which is behind the seat. Betting the B3300 is the same.
Koboman, On your 3200 how is the vent on the filler cap. Is it a hole or an actual vent tube.
My 3300 has only a rubber plug for the filler cap. It doesn't fit in tight...it kinda snaps in but once in you can spin it around.
Just been thinking my axle leak could have started with plugged vent as i only have 300hrs on a 2010 model.
   / B3300su rear axle vent tube #5
I have a rubber J tube on my filler. If you don't then you must have a vent elsewhere.
   / B3300su rear axle vent tube #6
You have a vent tube ahead of the filler plug. From the parts picture I would place it under the seat.
Thanks, I will take a look tonight to see if i can find it.
71069 (A49346)
71069 (A49346)
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2011 Ford Ranger Pickup Truck (A50323)
2011 Ford Ranger...
2016 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A51219)
2016 INTERNATIONAL...
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
