6110 or 5035
/ 6110 or 5035 #1
JMHTX
Montgomery, TX
2014 John Deere 5055 E Cab
Hey dealers,
With T 4 standards what is going to happen to these 2 models (6110 / 5035), I'm trying to decide between them.
I know the 6110 isn't Mahindra built and doesn't offer the Power Shuttle,
Is the 5035 a Mahindra built motor ? Is the 6110 Built by Doedong I do believe going to
get T4 Compliant without a Particulant filter ?
Knowing what you know.....Which one of these machines is better ?
Thanks
/ 6110 or 5035 #2
Both of these models in the T4 compliant versions will be renamed or renumbered, and both will be powered by the Mahindra mCRD engines.
/ 6110 or 5035
Even the 6110 made by TYM from Korea ?
/ 6110 or 5035 #5
I personaly have the 6110 and love it it has the Doedong engine and have had no issiues with it. That being said I ha e less than 100 hrs on it. I enjoy the cab and a/c . Motor is quite and fuel efficient. Cleared about 5 acers 20 something years of not being touched. Plenty of hp, comfortable to run for long hours. I also was looking at the 5035 and satisfied with my decision
/ 6110 or 5035
Thanks for the responses guys, I really like the 6110, I guess if I want one in the current config. I better make a decision.
/ 6110 or 5035 #7
Yes all tractors from the 30hp compact to the 85hp will have the New Mahindra engine in them. Right now the 5035 is a Mahindra engine also. The 6110 is not. Curious have you looked at a 6530?
/ 6110 or 5035
Yes, I have seen the 6530. The reason I like the 6110 over the 6530.... I want a cab tractor, and I want to be able to tow it with my 1/2 ton
F150. I think to the 6530 would be too heavy for that.
/ 6110 or 5035 #9
The 6110 will become the 2565. It will have a 3-cylinder 148.6 cubic inch turbocharged mCRD Mahindra engine. It's a lot of tractor for the money. 6110's have been out of stock at the DC's for a couple of months. I expect you can find a few on dealer's lots still, but not for long. The tractor weighs about 6500 with a loader, closer to 8000 with the rears filled. That gets sketchy with a half ton, but I know the newer pickups have some pretty impressive ratings for half tons, matching or exceeding some of the 3/4 ton trucks from the 80's.
/ 6110 or 5035 #10
My dad bought a 6110 on the same day as I bought my 5035 back in 2012. He has almost 400 hours on his and I have 300 on mine. He is about to take his back to the dealer for the 4th time. Twice for the front end controller and once for the a/c not working. This time it is the front end controls again AND his PTO won't work. I wouldn't take his tractor if he gave it to me for free. Even with water filled rear tires it wants to tip with a bale of hay up front and the forward reverse controls are clunky at best.
My 5035 with PST is awesome. I've documented a few things on here, but I (a mechanical novice) have fixed them all with electrical tape, white lithium grease or a fuse swap...with the exception of a defective hydraulic hose that showed up on the first day.
This is coming from a guy who would love to have a cab tractor....
/ 6110 or 5035 #11
Just as a heads up, I am pretty sure that they are going to have a new 3550 (5035 replacement) with a cab in the not to far future. Now that will be one sweeeeeeet machine. :drool:
/ 6110 or 5035 #12
Now you sucked me in. Would love that. My son has allergies so bad I'll never get him out there without the cab...and my dermatologist would get less work on the skin cancer to boot. If it would pull a batwing it would be perfect...
JOHN DEERE 7420 TRACTOR (A63291)
JOHN DEERE 7420...
Misc. Tires (A61573)
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
2006 Freightliner Auger Truck (A63688)
2006 Freightliner...
(1) 460/85R38 TIRE W/ 8 LUG RIM (A64280)
(1) 460/85R38 TIRE...
