jejeosborne
Thanks for the towing advice but I already have a 3/4 ton diesel that seems to do just fine for me without flooring it. If I need to tow anything bigger I get the lowboy out. Sounds like you might have a power issue if you are having to put the pedal to the floor that often. You should consider HP and Torque.
Funny how your statement acts like the ecodiesel is some underpowered truck. You really think an ecodiesel wont' climb a small hill without putting it on the floor? LAffin.
I have driven the ecodiesel and it is underpowered for towing it's rated capacity. 240 HP is nothing at 70 mph towing 8000 lbs. 100 percent throttle would be required to climb a small Hill at 70 mph. Simple math really.
The only time I have my foot on the floor is when I'm having fun. The ecoboost requires so little effort otherwise. Same torque as the ecodiesel with 125 more HP for the highway.
