Oil & Fuel 4210 ehydro how to pull
/ 4210 ehydro how to pull #1
Big Jon
Indianapolis, In
John Deere 4210
My 4210 started spitting some codes and decided it doesn't want to move. Hopped off and the oil line that lubes the fuel/injection pump has a split and oil all over ground.
Anyone know how to pull or push it into garage? Or do I just stick in neutral and go?
/ 4210 ehydro how to pull #2
Put the range selector in Neutral and go. Be sure to have it hooked to the pulling device before you put in neutral.
Thanks that did it... Some equipment you need to turn a couple bolts for a release.
ALLMAND ECOLED-RIG SPEC LIGHT PLANT (A68842)
ALLMAND ECOLED-RIG...
Unused 2021 HLA 48in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2021 HLA...
2016 FORD F450 CREW CAB SERVICE TRUCK (A69167)
2016 FORD F450...
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
225/70R19.5 Tires - Set of 2 (A68134)
225/70R19.5 Tires...
PORTA POTTY (A67714)
