questions to 2650/3350 owners
   / questions to 2650/3350 owners #1
ipwanab
Southern Indiana
Kubota Grand L3560
Does anyone own a b series cabbed tractor with turf tires that could tell me the real height ? I am contemplating kubota or deere, I know the deere is too tall to fit in a standard garage (7 ft). Last time I was shopping a 3030 with cab would fit (marginall if door was propped to be totally open). The only thing detracting me from the Kubota is the ground dragging mmm. I have searched but can not find anyone trying to rig suspended operation from the standard deck. I personally like turf tires but no one in my area orders or stocks the small tractors I would order with turf tires. The only u tubes I have seen of the Kubota cabs make the hydrostat sound truly obnoxious, is this real or exagerrated on the videos?
   / questions to 2650/3350 owners #2
I don't know if this helps. I have a B3030 with turf tires. I can go in and out of my garage with 8-ft high doors with no problem. I would calculate that you need 7'6" minimum. The B26 model requires even more room. I would guess that tractor needs a 9-foot door.
   / questions to 2650/3350 owners #3
My B2650 HSDC with R4tires will NOT fit under a 7 foot...The 8 foot high door in my shop needs to be fully opened to allow the flasher lights to clear . About 7 ft 8 in. min to be safe.
Thanksfor your help guys, I need to rethink my options , I can't bear to leave a shiny tractor outside.
   / questions to 2650/3350 owners #5
I used to own a B3030HSDCC and it just cleared a 7 ft garage door. I had to move the rear lights down a little and rotate the radio antenna but it did clear just barely. That was with the galaxy turf type tires. You may want to measure one and/or have a dealer measure one for you.
   / questions to 2650/3350 owners #6
I just put the B2650 back in my shop after blowing some snow and I remembered this thread from earlier. I took a tape measure and it is 85 1/2 inches from the top of the flashers (the highest point) to the floor with R4 tires. I would guess that it MIGHT slip under a 7 ft opening (not 6ft 11 3/4) but with the lights mounted lower, but I would likely leave a little paint behind as I passed under the opening. Don't know if turf tires are taller or shorter.
   / questions to 2650/3350 owners #9
Same here....They're real whiners.
I heard if you wrap a necklace around the rad, that stop's for a while,
but it does eventually return....lol
   / questions to 2650/3350 owners #10
I have a B2650 cab tractor on order and was concerned about if it would fit in a standard 7ft garage door. I had the dealer bring one by for a test fit and it just barely passes under the opening, but it does fit. This was with R4 tires. I am told turfs would be taller.
2016 Ford Taurus SE Sedan (A48082)
2016 Ford Taurus...
23ft Center Console Fishing Boat with 25ft T/A Boat Trailer (A48082)
23ft Center...
2015 Chevrolet 3500 Diesel Truck (A50490)
2015 Chevrolet...
2013 Chevrolet Impala Sedan (A48082)
2013 Chevrolet...
UNUSED Hydraulic Jack Lift (A50860)
UNUSED Hydraulic...
2022 Ram Bighorn 2500 4X4 (A50397)
2022 Ram Bighorn...
