JD 4100 won't start
   / JD 4100 won't start #1
Xjdigger
Member
Lincoln Maine
John Deere 5300
Hi
I have a JD 4100 compact that will not start. Cranks over and produces smoke but no fire. It is not the fuel shut off, produces white gray smoke as it turns over, have removed air cleaner to try starting. Tractor has been running fine never a starting problem. went out in the morning (Not cold) and did not start, just cranking over with no response.
3/4 tank of fuel
3 cyl diesel not complicated, what should be looking at?
   / JD 4100 won't start #2
Air in the fuel lines would be my first thought. Is it gear driven? Have you tried pull starting it?
   / JD 4100 won't start #3
Check your fuel filter for water and sludge.
   / JD 4100 won't start #6
Check your solenoid on the starter and the plugs on the alternator to make sure nothing popped off
Hi Sorry it took a while to get back. I just changed the fuel filter and it has not started yet. Battery was getting slow and I have it charging from boost.
I have the auto fuel shut off removed. has been for a while because something was wrong and it not opening the fuel valve. Been running like this since last year.
When I changed the fuel filter it was real dirty and ice frozen in bottom (not much) but I don't think it was to restrictive from allowing fuel to pass through.
fuel flows through the filter and then to a mechanical pump (like mini) chevy fuel pump.
how do I check fuel flow to determine that fuel is injected into the cylinders. There is smoke coming out of the exhaust pipe, but no attempt of igniting fuel?
Can I use starting fluid?
I don't know if this tractor has glow plugs. The manual does not show it in any starting procedure. I don't use starting fluid in my JD5300 never needed to anyway the glow plugs always work to get started.
   / JD 4100 won't start #9
These things don't need much to run, fuel, air and a good turning engine and your off.
Giving it a little shot of either wouldn't hurt, have someone give it a "little" shot while you turn her over.
You'll see if it wants to start with the either.
I know fuel air ignition and when it doesn't start there is a problem. I'm getting plenty of smoke so I assume it is getting plenty of fuel.
The tractor has been starting with no problem and it is not too cold around 30 - 40f. the 5300 burns the same fuel and starts right up. I did change the fuel filter and charged the battery for a good fast turn over and still not running. It is a pisser when you needs something to run when you need it and this is not typical with any John Deere I've had. I'll go down to the shop and get some starting fluid but I never had to use it before in a tractor and was afraid to spoil the glow plugs.
2015 INTERNATIONAL 4300 26 FT NON CDL BOX TRUCK (A51219)
2015 INTERNATIONAL...
STS MUD MIXING MACHINE (A50854)
STS MUD MIXING...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A51039)
2022 MAXXD BD14...
2021 Chevrolet Silverado Pickup Truck (A51039)
2021 Chevrolet...
Cat TH407C Telehandler (A51039)
Cat TH407C...
2007 TROXELL KILL/TRANSPORT TRAILER (A50854)
2007 TROXELL...
