3-Point Hitch 3-Point won't go down while running
/ 3-Point won't go down while running #1
dablack
Member
Rusk, TX
Kubota B2620
So I have had this problem for more than a year. I'm on my B2620 (100 hours) and I'm mowing a bunch right now. The land is a little rough so everyonce in a while the rear wheels will fall in a rut and I'm stuck. So I lift the 3-point so the rear wheels can get to the bottom of the rut and I drive out. Then after that I want to put the 3-point back down and the lever won't engage to lower it. I've tried oiling the shaft that the lever attaches to and everything else but nothing works. Here is the kicker. If I kill the engine and wait a second, it will engage. Then I'm all set again until it happens next time.
So, is there some adjustment that my 3 point needs? Why does it unstick after I kill the engine?
thanks
Austin
/ 3-Point won't go down while running #2
Is it still under warranty? It only has 100 hours and 1 year on it.
I'd recommend letting the dealer mess with it.
Or, go to Messick's website, put in your tractor's model number and request a parts diagram of the hydraulic system. They will email it to you. Then you can see how the linkage is set up. Maybe that will give a clue.
Kubota Parts | Full Service online retailer
/ 3-Point won't go down while running #3
That sounds like a good idea to do because later down the road that will be a big problem.
/ 3-Point won't go down while running #4
Maybe when you are stuck deep in a rut, the ground forces some control rod into jamming the 3 pt up and the hydraulics won't release it until the engine is shut down.
Cheer,
Mike
No more dealer for me. Everytime they get it, it comes back with something else wrong. No thanks. I've restored trucks, rebuilt engines and transmissions, and I'm currently building my own house. I think I can handle a little DIY tractor work.
"....the ground forces some control rod into jamming the 3 pt up and the hydraulics won't release..." I thought this too but the controls still work to pull the 3-Pt up! I pull the level to lift the 3-pt a little more and it goes up fine. Then I try to put the lever in the down position and it won't go. So I pull the level to lift the 3-pt again and sure enough it goes up fine. Try to put the lever in the down position and it won't go. The lever will only go to "neutral" or up. At that point I kill the engine for a second and then put the lever in the down position. It is like there was never a problem. Then I crank up the engine and I'm good to go.
This is only a problem sometimes. Sometimes it doesn't have a problem at all and I can change 3-pt height all day long. It is not temperature related because it does it in the summer and winter.
thanks
Austin
/ 3-Point won't go down while running #6
dablack
Have you tried opening up rate of drop screw?
If you are talking about the turn knob down below my ankles to adjusts the rate of drop, then the answer is no. That is a good idea. I might be mowing more this weekend. I will loosen it up a little and see what happens.
thanks
Austin
/ 3-Point won't go down while running #8
thanks
Austin
That might help, but it doesn't seem to explain why the lever becomes inoperative (stuck).
A tightened knob will hold the 3PH up even with the tractor off. You should be able to loosen the knob all the way and control the rate of 3PH drop by feathering the control lever.
Worth a try, however.
/ 3-Point won't go down while running #9
Try putting some grease on the feedback rod. That might be locking up sometimes.
GWDixon,
I agree. It doesn't explain it perfectly but I can't find anything that does.
Leejohn,
I'm thinking the feedback rod is the one with the spring on it? If so, it is nice and clean. I keep it so and oiled as well because I thought it might be the problem. I also keep the area where the shaft goes into the casing nice and clean and oiled. It might be something internal but I'm going to exhaust the external stuff first.
Austin
/ 3-Point won't go down while running #11
The only other thing I can see is the linkage at the control valve itself that would lock your lever up.. Try and look at a parts manual.
/ 3-Point won't go down while running #12
are you mowing with a MMM or a 3pt hitch mower? ( do you have weight on the 3 pt hitch to push it down???)
/ 3-Point won't go down while running #13
You may not have this on your tractor but I once had this issue and I thought I broke my 3pt. I inadvertently engaged my draft control to full on. When I attempted to lower the 3 pt, it only went down a small amount. I later realized the error, turned off the draft control and it worked normally.
HP
/ 3-Point won't go down while running #14
I'd vote for the rate valve knob under the seat. It seems to fool a lot of people....
Ok guys. Weird stuff here. I adjusted the rate valve and the 3 pt will drop fast sometimes but it won't others. I still have the problem. Sometimes while running the lever engages fine and the 3 pt drops fast, other times it barely moves. It eventually gets down but it is slow. Other times I have to kill the engine to get the lever to engage.
Grrrrrrr!
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
LandHonor Power Rake (A62183)
LandHonor Power...
LandHonor 10" Utility Fan (A62183)
LandHonor 10"...
(4) Light Up Arrow Traffic Signs (A62183)
(4) Light Up Arrow...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
Case SV280B (A62177)
