3-Point Hitch PTO problem with Kubota L345
/ PTO problem with Kubota L345 #1
carlubu1
Member
Yazoo City, MS
Kubota L345
I was bush-hogging and hit a stump. Instead of the shear pin on the mower breaking, something stopped the pto shaft from turning. I can turn it by hand and feel no kind of resistance. Initially, the pto shift lever would move into low or high without engaging, but then would move only into high. Otherwise, everything seems to be OK. What happened inside??
/ PTO problem with Kubota L345 #2
What do you mean the PTO lever wont shift to high or low? or are you talking about the range selector
The pto is activated by shifting a lever from neutral to low range or high range. The pro was operating in low range when the mower hit the stump.
/ PTO problem with Kubota L345 #4
The mower's shear pin doesn't always save the tractor gears. I did the same thing years ago with my first L345. After clobbering a rock, mine kept turning but had a loud clicking - indicating broken gear teeth. Yours sounds like a gear failure too. The machine will need to be split to find out which parts are needed. BTDT as they say so any questions fire away.
Guess I'll have to haul it to somebody who knows a lot more than I do. Thanks, rbargeron. I was hoping for something simple
/ PTO problem with Kubota L345 #6
If you have basic mechanical skills, a flat floor, can borrow two rolling floor jacks, it's not a huge job. Not everybody's cup of tea, but can be a confidence builder and will save a few hundred dollars. Can think of it as paid playtime.
/ PTO problem with Kubota L345 #8
Have you tried moving the lever while your edging forward with the tractor a bit?
/ PTO problem with Kubota L345 #10
Might be worth taking the frog off and getting a peak inside
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
Giyi Mini Ex Attachment Set (A60463)
Giyi Mini Ex...
(INOP) 2012 FORD F450 XL SUPER DUTY SERVICE TRUCK (A59823)
(INOP) 2012 FORD...
1999 CHEVROLET C7500 UTILITY TRUCK (A59906)
1999 CHEVROLET...
