Before I built them I looked up the weights and figured it was going to be 120 pounds. I would guess it is close to that maybe 150 tops. The cage is 3/16×2 flatbed. The top and bottom rails for the forks are 2" angle 5/16 thick. The vertical supports where the brackets to attach to the tractor are 2x4×1/8 as well as the forks. I believe the width is 42 or 44 and the forks are 40 long if I remember correctly. I copied the brackets on the bucket and had them plasma cut for 60 bucks. I have under 200 into these, and probably 20 hours of my life
