Forks is is there anything I can't do with these
   / is is there anything I can't do with these #1
pardon my french
west hartford ct
kubota l4740
20141107_070127.jpg is there anything I can't do with these what are they worth to you most can't live without forks I just got them today
   / is is there anything I can't do with these #2
You can't cut your grass with them
   / is is there anything I can't do with these #3
Might be tough pushing snow with forks.
   / is is there anything I can't do with these #4
You might be able to use them to split wood tho if they are sharp enough and you can get enough traction
   / is is there anything I can't do with these #6
View attachment 397671 is there anything I can't do with these what are they worth to you most can't live without forks I just got them today
You'll probably have a lifting limit of around 1,800-2,000 lbs, give or take. Some stuff that comes on pallets can weigh more, so you'll want to know the weight of anything really heavy before trying to lift.
That's a very nice setup you've got. The QA and forks makes me envious... I've just got clamp-on forks and a pin-on bucket, but even they are very handy.
Enjoy!
   / is is there anything I can't do with these #7
And DO NOT use them to lift the front end of your car so you can work under it. ;)
2005 KENWORTH T800B TRI AXLE BOBTAIL KILL TRUCK (A55745)
2005 KENWORTH...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
2 - TRUCK WHEEL DOLLY (A55745)
2 - TRUCK WHEEL...
GODWIN 3,500 PSI HYD. POWERPACK (A55745)
GODWIN 3,500 PSI...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A55314)
2022 John Deere...
