Forks is is there anything I can't do with these
   / is is there anything I can't do with these #1
pardon my french
west hartford ct
kubota l4740
20141107_070127.jpg is there anything I can't do with these what are they worth to you most can't live without forks I just got them today
   / is is there anything I can't do with these #2
You can't cut your grass with them
   / is is there anything I can't do with these #3
Might be tough pushing snow with forks.
   / is is there anything I can't do with these #4
You might be able to use them to split wood tho if they are sharp enough and you can get enough traction
   / is is there anything I can't do with these #6
View attachment 397671 is there anything I can't do with these what are they worth to you most can't live without forks I just got them today
You'll probably have a lifting limit of around 1,800-2,000 lbs, give or take. Some stuff that comes on pallets can weigh more, so you'll want to know the weight of anything really heavy before trying to lift.
That's a very nice setup you've got. The QA and forks makes me envious... I've just got clamp-on forks and a pin-on bucket, but even they are very handy.
Enjoy!
   / is is there anything I can't do with these #7
And DO NOT use them to lift the front end of your car so you can work under it. ;)
CAT 430E BACKHOE (A55745)
CAT 430E BACKHOE...
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
PALLET OF 2" X 4" STEEL TUBING & SITE PANELS (A54757)
PALLET OF 2" X 4"...
GODWIN (INOPERABLE) 3,500 PSI HYD. POWER PACK (A55745)
GODWIN...
1995 Koehring LRT-110 7.5 Ton 4WD Rough Terrain Crane Truck (A55787)
1995 Koehring...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
