Attachment to turn grass to dirt...
   / Attachment to turn grass to dirt... #11
Nothing to it really. If you have a lot of rocks, the Harley rake is going to work better than the other two. If not many rocks, either the disc or tiller will work. Kill the grass first. If you don't, you will have ground-up sod that will try to regrow. If you don't kill the grass, at least mow it short to help stop regrowth. The tiller set to just a couple inches deep will give you a dirt track in 2 passes. The disc harrow will take a few passes depending on disc model, setup and weight.
   / Attachment to turn grass to dirt... #12
A pic would help us determine how to approach
   / Attachment to turn grass to dirt... #13
The RoundUp suggestion is a good one. Now that RoundUp is off-patent, the generic versions of glyphosate might be a bit cheaper and just as effective. Don't spray on a windy or rainy day if you care about effectiveness with minimal collateral damage.
   / Attachment to turn grass to dirt... #15
Old thread but curious to your outcome. I am looking to attack the same thing in my yard.
New Holland 1431 Discbine (A50515)
New Holland 1431...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2019 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2019 UTILITY VS2RA...
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
2017 GEHL RS5-19 TELEHANDLER (A51242)
2017 GEHL RS5-19...
