Beet juice uses and properties
   / Beet juice uses and properties #1
N7943h
Skagway Alaska
Jd318 jd510
I Have read lots on here about the joy of beet juice for weighting tires but I am wondering how well it would work as a antifreeze solution in a boiler. I can't find much about that anywhere searching the net. I would like to know things such as heat transfer rates, behavior when heated and such. Do any of folks have knowledge you can share. ??? I am wanting to move away from glycol and need protection to -10f.
   / Beet juice uses and properties #2
I have not heard of beet juice being used as antifreeze. I know it has a high sugar content and may not be the best thing to use in a boiler. I think your best bet is to contact your boiler manufacturer and see what they recommend. Also, contact RimGuard directly and see what they have to say. I can see this becoming a real mess - like hot maple syrup & even leading to additional corrosion problems.
   / Beet juice uses and properties #3
"beet juice" is a colloidial mess, not a clear solution like you need to use in a boiler. Think of slimy gooey, brown gravy. Who know what would happen if you heated it.. probably get thicker and would stink to high heaven. So No, definitely not what you want in your boiler.
   / Beet juice uses and properties #4
I envision the world's largest fungi factory.
2019 TerraGator 7300 Spinner truck (A55315)
2019 TerraGator...
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
CASE 610 Sprayer System 2000 Gallons (A55315)
CASE 610 Sprayer...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2017 Ford F-350 Ext. Cab Pickup Truck (A56858)
2017 Ford F-350...
2002 MANAC 48'  WALKING FLOOR REFUSE TRAILER (A57880)
2002 MANAC 48'...
