Mowing Well, it was bound to happen sooner or later..... and today it was my time
   / Well, it was bound to happen sooner or later..... and today it was my time #171
I'd get stung rigging up that vacuum
   / Well, it was bound to happen sooner or later..... and today it was my time #172
Nawh you rig it up at night when the little dears are asleep in side their nest. Then turn it on, bang on the side of the house then run like heck.:drink:
   / Well, it was bound to happen sooner or later..... and today it was my time #173
   / Well, it was bound to happen sooner or later..... and today it was my time #175
I have used a shop vac several times. If you poison the hole but the nest is on the other side of the attic, no effect. I hate buying poison and hate my family being near it. Except for ants & termites I will buy poison and use sparingly. I don't like killing pollinators, but if they nest in the wrong place I will be the winner.
Here's a few things I learned being the family "shop-vac guy" for wasps.
1) Bugs can't fly in a hose - they just tumble at the speed of the flow, and the impact kills them. Like hitting a windshield at 100 mph. You don't need to kill them more.
2) Duct-tape a 10-foot stick of rigid 2" ABS or PVC pipe to the flex hose. It's much easier to place a rigid pipe near the hole, and you are back a ways from the action. The wasps focus attention on the end of the pipe near the hole, not interested in the person holding the pipe.
3) The worker bees are feeding the queen. When they don't arrive with food & water, eventually she will get hungry and fly out. Once you've got the queen, the hive is 'dead'. I'm not 100% certain of this.
4) I found that you can run it for an hour or so, then turn it on again later, and get some more, and after 2 or 3 cycles you've won.
I rigged this up so I could see if they were still coming. It's a glass bottle duct-taped to a drainpipe "Y". You will have no doubt they are killed on impact. You can see in the pic there are insect parts spinning around in the glass jar. You can open the shop vac right away there is some movement but no flying bees.
404711d1420083074-well-bound-happen-sooner-later-vacuuming-wasps-26-jpg
   / Well, it was bound to happen sooner or later..... and today it was my time #178
Now that's man vs insect...but not a good method for wasps in the attic!
   / Well, it was bound to happen sooner or later..... and today it was my time #179
horrible idea for attic, but a lot of fun to watch these guys..
   / Well, it was bound to happen sooner or later..... and today it was my time #180
Sodo I used your vacuum and chunk of PVC pipe method to get rid of about a dozen red wasps in our kitchen skylight this fall. The wife is deadly allergic to wasp stings, so she vacated the premises and I did the vacuum cleaner and pipe thing. Worked perfectly. I was not threatened at all being several feet below them, and the vacuum just sucked them up one by one. Problem solved.
2008 Ford Taurus SEL Sedan (A55973)
2008 Ford Taurus...
2020 MACK P164T (A58214)
2020 MACK P164T...
Computerized Wheel Balancer (New/Unused) (A59225)
Computerized Wheel...
2014 Ford Fusion AWD Sedan (A56859)
2014 Ford Fusion...
CORN SHELLER MOUNTED ON WOOD BOX (A58374)
CORN SHELLER...
PENDING SELLER CONFIRMATIONS (A58018)
PENDING SELLER...
