John Deere 4410 wont move (HST)
   / John Deere 4410 wont move (HST) #1
wango tango
Peoria IL
Just like it says....
the power steering works, the rocker shaft works, pto works.
any ideas what to check?
   / John Deere 4410 wont move (HST) #2
Any error codes flashing? Check wiring under the pedals, and battery voltage.
dont see any error codes. i'll check the wiring...guessing it is ok.
how could battery voltage be an issue?
to be clear, it starts and runs just fine.
   / John Deere 4410 wont move (HST) #4
I have read other posts, that sometimes if one pedal or the other is not centered, it will not move, because it does not know if it is in forward or reverse.
   / John Deere 4410 wont move (HST) #6
What can you tell us that was going on with the tractor prior to it just "won't move" ?
Winner winner!!! Fwd pedal stuck
   / John Deere 4410 wont move (HST) #8
IF it happens again, it might be worth crawling under the tr side and taking the cover off. Lube the springs or they could be broken. The springs get rusty and then break.
   / John Deere 4410 wont move (HST) #9
I strongly suggest you use Fluid film on those pedals and definitely the range lever where it goes into the transmission case!
Glad you found the problem!
   / John Deere 4410 wont move (HST) #10
I just had to do this, on mine, the reverse pedal was not coming back up all the way. Simple lube fix, tough to get the cover's plastic barb retainers out without damaging them. But just glad the fix was cheap and simple.
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A49461)
2015 SkyJack SJ86T...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A51039)
2014 Dodge Ram...
2011 PETERBILT 389 (A50854)
2011 PETERBILT 389...
2018 PETERBILT 579 DAY CAB (A51222)
2018 PETERBILT 579...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51242)
KNOW BEFORE YOU...
AMG M 35A2C drop side 2 1/2 ton 6 x 6 (A50323)
AMG M 35A2C drop...
