Bolens/Iseki TX2160 voltage regulator
   / Bolens/Iseki TX2160 voltage regulator #1
TX2160
shreveport, LA
Bolens/Iseki TX2160
I have a Bolens Iseki TX2160 with a k3b Mitsubsihi engine. I need a voltage regulator for this tractor. The alternator is a Mitsubsihi AH2035M4. (35 amp)
Can anyone tell me the correct voltage regulator for this tractor? NEED A REPLACEMENT REGULATOR!!!!
Thanks
   / Bolens/Iseki TX2160 voltage regulator #2
can you post a picture or the numbers off your old regulator they were several different ones used on this series of tractor have picture books that will help me find it for you
   / Bolens/Iseki TX2160 voltage regulator #3
Another option is a one wire GM alternator. I had good luck with the two I bought.
   / Bolens/Iseki TX2160 voltage regulator #4
The alternator is a Mitsubsihi AH2035M4. (35 amp) NEED A REPLACEMENT REGULATOR!!!!
I just Googled Mitsubsihi AH2035M4. One website shows it listed for your Iseki and shows it is equivalent to Lucas LRA1091. More Googling on either of these numbers should reveal an automotive application, say 89 Subaru or something. Then go to Autozone and buy a '89 Subaru' regulator for $20.
20 or 35 amp alternator will likely use the same regulator.
2015 Geringhoff NS830 (A47164)
2015 Geringhoff...
2012 Komatsu HM300-3 Offroad Dump (A47371)
2012 Komatsu...
Ryobi Compound Miter Saw (A48837)
Ryobi Compound...
2016 Ford Escape SUV (A48082)
2016 Ford Escape...
New Tractor Seat (A47371)
New Tractor Seat...
Forks (A49251)
Forks (A49251)
