Snow Equipment Buying/Pricing Value of JD quick attach 7' manual angle snow plow
   / Value of JD quick attach 7' manual angle snow plow #1
loum
Vermont
850 JD
I have a snow plow I bought with my tractor and don't even plow my own driveway any more. Can someone advise on how best to sell this item and what price I should ask?
It is in very good condition but I live in rural VT approximately equidistant from Glens Falls, NY and Rutland, VT. Someone would have to drive here with a trailer, I think, as I doubt I could load it into a pickup.
Thanks for any help.
   / Value of JD quick attach 7' manual angle snow plow #2
Around here, I'd pay 4 to 5 hundred for it.
thanks for input, skyhook. I'll try a local paper and craigslist..........Lou
   / Value of JD quick attach 7' manual angle snow plow #4
Not the best design, but was probably 1200-1500 new.
   / Value of JD quick attach 7' manual angle snow plow #5
Craigslist is a good place to advertise it particularly this time of year.
   / Value of JD quick attach 7' manual angle snow plow #6
Look to see what a new one of the same brand costs. I would bet $1200 to $1500 is probably close. The manual angle option really makes a plow that size less desirable. I would start at 50% to 60% of new and see response. If you are not getting any responses to you add, include "reasonable best offer".
Also, find out how much to add a power angling system. That will help you sell it so people know what it will cost to make it so they will want to use it without climbing on and off the tractor to angle it. Information is valuable.......
Take GOOD pictures up close so people can see exactly how it works, etc. Post several GOOD pictures from various angles so people can really see it.
Also do some research so you know what it fits so you are advertising in the right category. If it will only fit one brand of tractors mounting system, that is a big drawback. If the mounting system is more universal, it will be easier to sell and command more money.
Include in the Advertisement and the listing title the brands of tractor it will fit. Many people search craigslist by the brand name of the tractor they are looking for attachments.
The more you know about what you are selling, the easier it will be to sell and you will command more money. Simply google the names on the plow and you will learn a ton. Also google a good picture of the plow and you may learn even more.....
A lttile investment of your time will put more money in your pocket in the end......It always does.
   / Value of JD quick attach 7' manual angle snow plow #7
I might be interested...sent you a PM.
   / Value of JD quick attach 7' manual angle snow plow #8
Whats wrong with the design? Will this fit a 1025 loader frame? I may be interested if Roy isn't.
   / Value of JD quick attach 7' manual angle snow plow #9
It would technically would fit, but its to big and heavy for your 1025.
   / Value of JD quick attach 7' manual angle snow plow #10
I would give $400 as is, but I am thinking in terms of how much it would cost and how much work to convert it to SSQA and adding hydraulic power angle. But if a guy had a JD, it might be worth quite a bit more to him. It looks to be in good shape.
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2021 McFarlane IC-5140 Vertical Tillage Tool (A50657)
2021 McFarlane...
2007 Ford F-150 Pickup Truck (A50323)
2007 Ford F-150...
Wilrich Field Cultivator (A50515)
Wilrich Field...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
John Deere 946 Center Pivot Rotary Mower-Conditioner (A52128)
John Deere 946...
