Help me understand Third Function Remote please
/ Help me understand Third Function Remote please #1
lzicc
Pittsburgh, Pa
Kubota B2650
I'm looking into installing a third function remote on my L4060. I have allot of information on this from other post, but need to get a better idea how I would do this and how it would work.
To do this, I would need to tap into my FEL control valve. That is where I get a little lost on which hoses I tap into. I'm guessing I need to tap into the supply that goes to the FEL valve. Once I tap into that, I need another valve to operate the third function. The hoses that I tapped into would go to this new valve. Then I would run a set of hoses from the new valve to the front of the loader area with quick disconnects on them. Is that it? I hear allot about solenoids to do this. Where does this come into play or is this only used if using a diverter valve? I attached 2 pictures of the right side of my FEL. It looks like there are to plates that could take off to run the lines to the Third Function Remote through the FEL arms which would keep them protected.
/ Help me understand Third Function Remote please #2
I would first check whether your tractor has a spot near the rear to connect the remote. Mine has a spot under the right rear wheel, all you have to do is buy an adapter to put over that spot and connect the hoses. It's a lot easier than running hoses from the FEL.
That is a good question, but I would still have to run hoses up to the FEL. This would be for a remote to the front end to operate other implements that require additional hydraulic feeds. I may not be understanding what you mean though. This is very new to me.
/ Help me understand Third Function Remote please #4
Thanks TripleR, I watched all 3 videos and it really helped me understand how this works now.
A few questions, once this is installed, the third function operates using the 2 momentary switches and not the joystick movement, correct?
What is the power beyond hose for? You have a supply and a return and then a power beyond? I did not realize this.
My tractor does have a BH, so the power beyond hose would go from the FEL control valve, to the BH and from the BH connection would go back to the power distribution block.
So there is no actual lever for the third function, it is operated by momentary switches.
/ Help me understand Third Function Remote please #6
Yes, my joystick has a button below the handle you press to make the third function active, when it turns green you can use the momentary switches in the handle to open or close, so no movement of the lever is needed though you can if needed; I sometimes change the angle when going into a brush pile etc.
Sorry I don't know much about hydraulics and rely on J J and others for specifics.
That's ok, this really helped me understand things. I don't know why I had in my head that I needed to put another joystick in to handle the third function.
I emailed Messicks parts and they can sell me the Kubota kit for the third function for $899 plus shipping which is not much higher price than a non OEM unit. I think the non OEM kit is $850.
/ Help me understand Third Function Remote please #9
What are you trying to control?
JJ, first off a Rock Hound, then maybe down the road a grapple bucket.
/ Help me understand Third Function Remote please #12
Not sure if the rock hound uses a hyd motor or not. I would want to go with 1 solution that would be suitable for both. So if I used the parts from Belieynet, I would also need the hoses to reach to the FEL which I would guess would be about $100 for those. I would not be sure how to hook this up though. I'm not too savvy with this right now, so I am asking allot of questions.
Here is what I see on my tractor and please forgive me, I am novice on how hydraulics work but do want to learn.
This is a picture of the FEL hoses connection. This is where the FEL connects to hoses which those hoses connect to a junction block.
This picture is the other end of those hoses from the first picture. It just looks like another junction block. You can see the gray steel lines on the other side of that junction that go underneath of the tractor.
This is a picture of where the gray steel lines go to underneath the tractor.
Where does the third function splice into this? Yes, I'm confused on all the lines.
/ Help me understand Third Function Remote please #15
If you buy a kit for your model tractor, it will have instructions. They will tell you which line to remove to connect the third function valve lines. Mine is a smaller tractor and the valve is somewhat different but I think they all probably use the same theory. I had to remove a pipe that went from the valve to the tank. There were two hoses that went into the two open holes that were left. It was pretty simple really.
/ Help me understand Third Function Remote please #16
I believe that for your situation, you are best off getting the OEM system. Forget about trying to save $50-$100, get the system that is supplied by Kubota for your tractor. ;)
/ Help me understand Third Function Remote please #17
Is power beyond not an option and more robust?
/ Help me understand Third Function Remote please #19
If the Rock Hound has a hyd driven motor with a lot of centrifugal force, then you need a motor spool valve, whether it is a lever or solenoid valve.
A motor spool valve should not be used with a cyl circuit.
So in essence, you really need two valves.
One type valve that will lock a cyl in neutral, and another valve that will let the hyd motor wind down as it is acting like a pump when you release the valve.
You could get by with a two spool valve with one spool a cyl spool and the other spool a motor spool.
It also has to do with the money you want to spend.
The basic 3rd function kit is about $400 and a two valve 3rd kit might go from $500 to 800.
Can you do all the work yourself?
To install a 3rd kit, you simply interrupt the PB from the FEL valve at the hyd blk and add the 3rd kit in series with the flow path.
Your manual will show you the ports on the hyd blk.
/ Help me understand Third Function Remote please #20
If it's anything like my L3200, you will intercept the power-beyond line coming off the loader (that currently runs to the 3-pt). Supply the rear remotes with that. And then the power-beyond port on the remotes routes back to the 3-pt. If you have a backhoe, it's already in that position in the power-beyond loop, so it's just a matter of inserting the rear remotes after the backhoe and before the 3-pt.
I'd say get the Kubota kit if you want pretty lever integration. Otherwise, it's not that hard to figure out and you'd save $$ with off the shelf valves and parts. Plan to spend some time figuring hose requirements and lengths, fittings, etc. The Kubota kit takes care of that stuff as well, but is not without some glitches you'll need to deal with.
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63689)
Greenworks...
Kubota V3600-T-E102 Diesel Engine - Pump Takeout (A63689)
Kubota...
2022 EZ-GO ELITE...
Cat CB24B (A60462)
Cat CB24B (A60462)
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A63689)
2008 Ford F-250...
