Jinma Chipper Feed Roller Connection Problems
/ Jinma Chipper Feed Roller Connection Problems #1
Smalljobs
Gold Member
Massachusetts
Jinma 284
Last year I had trouble with the male square on the end of the feed roller shaft. It rounded off so, rather then replace the roller, I welded the drive shaft knuckle square socket right to end of the feed roller. So far so good until this year when the same drive knuckle itself rounded inside its own connection - the one held together with the C-ring.
I just bought a heavy duty driveshaft from Tommy and now have to make another decision:
1) I can cut off the old knuckle connector and replace it with a high strength impact male 1/2" drive. It would be welded to the old feed roller and I realize it is once again a one way street. I might have to slightly shorten Tommy's shaft so that it doesn't bottom out like a "too long" PTO shaft. I think it's all doable.
2) The alternative is to buy another feed roller and just swap out the parts. I'm worried the new feed roller male drive might repeat the same rounding off problem I had with the existing feed roller.
For those of you who have not seen Tommy's high strength shaft it's really robust! FYI, the male female telescoping parts are larger than the old shafts and are therefore not interchangeable. I still have the male part welded to the feed roller and it just spins around inside the new heavy duty one.
Any recommendations?
/ Jinma Chipper Feed Roller Connection Problems #2
Option 1 would probably work OK, providing that socket extension will fit properly thru the bearing inner race. If it didn't workout, you always have option 2 to fall back on. I find it unusual that the squared end of the roller shaft would round-off That would imply that it was VERY loose in the first place and able to wear enough that the torque could twist the outer part past the corners of the squared part. The only way I see this hapening is if that end of the Ujoint, like a broken socket, is split allowing it to expand under high torque and rotate around the squared portion. Allowed to continue this would turn both squared parts round pretty quickly:)
I just got done going thru all of my parts while I re-designed the safety mechanism, as the slider assembly just never would release with the roller under load, which will be exactly when you need it the most. I added a spring loaded belt tensioner idler pully and a kicker mechanism that loosens and then derails the belt and kicks it off the drive pully when the safety bar is pressed all the way down. All my driveshaft parts are still tight with no appreciable wear. In fact, the only issue I have had with the driveshaft is one of the Ujoint pins came out and the drivechaft disassembled itself. But I found all the parts including the pin and it all went right back together. I welded the head of the pins in place. So I wonder what caused yours to round off?
Hi Ron,
My driveshaft is the older style with no pins. It's the telescopic shaft with the C-clip retained knuckles (not yokes) at each end. See photo. The first failure was at the roller shaft and it was the roller male that rounded off. I would never have taken the drastic step to weld it if I could have just replaced one end of the telescopic shaft. Since the roller male end was ruined, it made sense to weld it. Yep, see photo where the welded knuckle can no longer pass through the bearing block.
The failure last week was at the other end of the shaft, in fact, it was the knuckle joint on the female half of the shaft. The male drive on the worm gear output is OK but now it's inside that C-clip retained joint.
The new shaft from Tommy has robust yoke "universals" on each end.
The welded half of the old drive shaft will not pass through the bearing. If I cut it off and weld on an impact socket 1/2" male drive, I'll still have the same problem where it cannot pass through the bearing. I don't want to mess up the bearing and the welded coupler is right up against it now.
The more I think about it, I may buy another roller and then I'll have OEM stuff from start to finish and maybe some sort of warranty backup. This way, I'll have the improved driveshaft, new roller, and basically all stock parts from the roller to the worm drive. I'm not hard on this chipper and have no explanation why the roller male failed unless it had poor or no heat treatment right from the factory.
/ Jinma Chipper Feed Roller Connection Problems #4
Got it... Mine came with the ujoint shaft... I wasn't aware there was another driveshaft in use...
Problem solved: Bought myself two new feed rollers along with pair of new flanged bearings for same as part of May China business trip. Now, I've got plenty of spares.
/ Jinma Chipper Feed Roller Connection Problems #6
Nice. Hopefully some spare knives too.
When I imported the chipper I ordered and received spare knives, spare anvil, and spare bolts! I have a lifetime supply of those parts now.
Tommy is "Affordable Tractor" and you can easily find them online. The driveshaft is shown along with other Jinma chipper parts.
/ Jinma Chipper Feed Roller Connection Problems #10
Been contemplating taking the old (but still works) drive shaft, lopping off the ends and putting on real greasable u joints with alemite fittings, utilizing the square broached ends to engage the roller and the clutch. In as much as I own a machine shop, it's very doable. I see ther is a u-tube video where someone did just that but there isn't a link to who, what or where.
Mine is the new style with crude U joints already.
BTW. for an FYI, the drive belt is a 3L 40, available at any auto parts store for a couple bucks.
The infeed drive is the weak link far as I can see.
Been running mine behind my M9000 Kubota with 87 PTO ponies. 8" hardwood logs, no issue. I did add a Weasler 3 plate fricton clutch btween the input shaft and the PTO on the tractor and had to add an additional 8" to the base to get the driveshaft to run level, my Kubota is a Class 2 3 point.
I also added air holes to the knife access plate to allow more air into the cutter disc. No need to run it at 540 PTO, I run about half that. ven with an 8" knot, I can't get the tractor up on boost.....
/ Jinma Chipper Feed Roller Connection Problems #11
I bought mine used for a grand and it came with a set of spare knives that appeared to be very worn. Took about 5 minutes on one of our surface grinders to make them 'new' again.
With as many (Chinese chippers out there and the cost of replacement knives, I shoud offer a knife grinding service, we have the equipment to do it easily.
/ Jinma Chipper Feed Roller Connection Problems #14
Shoulda bought a Woodmax........
Not really. Every Woodmax Chipper is an imported Chinese chipper anyway. I bought mine used for a grand. Show me a Woodmax for a grand... you can't.
Shoulda, coulda, woulda don't count IMO.
Nothing wrong with the Jinma a little 'help' won't cure.
/ Jinma Chipper Feed Roller Connection Problems #15
If we can help you give us a call 979-865-4002 or look online Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
Tommy
I'll do just that. Far as I can tell it's a sturdy unit. I'm inputting at least 2 times the recomended pto power with no issues. I'm running this on an ag tractor, not a compact. Like I said, I had to extend the base 7" (with angle iron legs) just to get the PTO in alignment and so far, I've chipped at least a dump truck full of wood chips. I have about 10 years of catching up to do with our trees and it sure beats a burn pile. A very good investment far as I'm concrned.
Going to modify the feed roller lift assembly this winter to match the later models. Mine has the single lift handle on the right side and I'll modify it to the single, centered handle lifting both sides of the feed roller similar to what your new models have, which IMO, is a better arrangement.
One issue I has was the bed blade (anvil) sits proud of the bed recess and presents a ledge that branches tend to hang up on when feeding. I took out the bed blade and ground a chamfer on the backside to allow the branches easier entry. I realize I loose the capability of reversing the bed blade but regrinding the bed blade is a simple matter of removing it, taking it in the shop and putting it on the surface grinder and squaring it. Both of our grinders hold 0.00001 not that thats important.
Other than that, really no issues other than the infeed roller driveshaft, which is fixable. What I'll probably do is give you a call and order a replacment and modify that one with greasable U joints. The one I have presently can be greased via push fittings in the crosses but it's wallowed out pretty bad.
I wonder if there is a market for knife grinding. The one grinder we own can handle dimensional work up to 25" in length by 14" in width at any angle up to 90 degrees from vertical.
Just curious in as much as the knife sets aren't cheap.
/ Jinma Chipper Feed Roller Connection Problems #16
And the "little help" may differ. On mine I've a bolt hole on the chute that was drilled wrong and if it bugs me enough I'm going to have redrill and tap.
But my thinking is I'd like to find the parts CHEAPLY to make it a 360 degree rotating chute.
/ Jinma Chipper Feed Roller Connection Problems #17
I had some of the parts to do that with, I think I may have a used one also
Send me a e-mail to tommy@affordabletractorsalesco.com I will take a look and send you some pics if you want. We have sold several of the kits. You just remove your old discharge chute, mount this 360 adaptor, then put the new chte on.You may have to drill a hole or two but not a big deal.
Tommy
Afordable Tractor Sales
"Your Jinma Parts Superstore"
/ Jinma Chipper Feed Roller Connection Problems #18
Has anyone ever converted there mechanical drive feed roller to a hydraulic feed roller?if so what kind of costs are involved and how did it work out? The mechanical drive on mine is a piece of junk. Been through three sets of stock ball type u joints. I completely rebuilt the driveline using heavy duty universal slip joints from Sears craftsman tools and it worked great for a long time finally just broke that too. I saw Tommy had the upgraded driveshaft I wonder how that works. And if it's any more durable or still problematic
/ Jinma Chipper Feed Roller Connection Problems #19
Fill it (with weld) drill it and re-tap it, no big deal. I lik the woodmax style rotating chute but it's not a deal breaker. I suspect that woodmax orders enough from China that they can specify certain changes. I get inquires from Chinese companies constantly wanting to make me parts...I delete thm all.
The Jinma is cobbly but it works and thats the bottom line.
/ Jinma Chipper Feed Roller Connection Problems #20
I could have went to the local box store and bought a gasoline powered chipper that would maybe run some twigs (I don't consider the box store chippers to have much capacity, a 5 horse motor don't have much grunt in the first place) for 600 bucks or buy somthing that runs PTO power for a couple grand, but this one appeared on CL one morning so I grabbed it.
You don't find many used ones. That tells me that while they might not be perfect, they do the job so owners don't sell them.
2021 Scag Turf Tiger II 52in Zero Turn Commercial Mower (A64194)
2021 Scag Turf...
2009 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A64556)
2009 Chevrolet...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
2007 Ford F-150 Pickup Truck (A64556)
2007 Ford F-150...
2018 Chevrolet Tahoe SUV (A64194)
2018 Chevrolet...
2014 Freightliner 114SD T/A Dump Truck (A64556)
2014 Freightliner...
