bar/chain oil vs used engine oil?
   / bar/chain oil vs used engine oil? #21
Anyone who runs chainsaws for a living day in and day out will tell you screwing around with crap oil is foolhardy, to say it politely.
Sometimes in the winters I would add a bit of diesel or gasoline into my bar oil just to lighten it up bit. This is from a guy who would burn a gallon to gallon and a half of gas, and roughly three quarters of a gallon of bar oil in a six hour time period. When your paycheck relies on your saws, you don't get very far on the cheap.
   / bar/chain oil vs used engine oil? #22
I bet used engine oil is fine for the chain & oilers, but it depends how well the oil was "cared for" after being drained from the engine. Was it dumped in an old bucket with a bunch of dirt? Or carefully collected, for re-use in another piece of eqpt? There is a difference.
I tried used engine oil in a saw, 2 tanks. It was messy. It was runny. Everywhere you put that saw it leaves a mess. Everywhere the chain sprays is a mess, so you have to be careful where you point it. Your clothes get black. The very few $$ saved was lost dealing with the mess, I wouldn't do it again.
   / bar/chain oil vs used engine oil? #23
One other plus at least for some bar oil is it's synthetic and made to break down harmlessly instead of flinging carcinogens all over your property.
   / bar/chain oil vs used engine oil? #24
I bet used engine oil is fine for the chain & oilers, but it depends how well the oil was "cared for" after being drained from the engine. Was it dumped in an old bucket with a bunch of dirt? Or carefully collected, for re-use in another piece of eqpt? There is a difference..
You got it. That's where one would have to pay attention/ The oil in the car is very, very clean by bar oil standards, Letting it flow across the bottom of a dusty dirty oil pan, into a dirty collection pan is where any real particles would be drawn in.
   / bar/chain oil vs used engine oil? #25
for get that. these guys like heavy metals and stuff in their firewood they heat their homes with. what's a lil inhaled benzene.. right?
   / bar/chain oil vs used engine oil? #26
What do you think happens to the millions and millions of gallons of crankcase oil that 'disappears' in less than perfect engines across the globe?;)
   / bar/chain oil vs used engine oil? #27
it's not like it's making the end of the log i'm heating my home with black. it is at least diluted across the entire environment. not a wet black smear on every log i cut. comparing millions of gallons and the surface area of the globe is a far cry from the concentration you would get on a 18
" quarted wood stove or fireplace split with a black oily end!
   / bar/chain oil vs used engine oil? #29
If you got a wet black smear on every log you cut, you need to turn down your oiler rate. No need to waste precious oil.
   / bar/chain oil vs used engine oil? #30
ok.. here's the college answer since you didn't like the other one.
drops on the road from the leaky car is essentially a non point source. ( it happens, we know it happens.. we can't trak down and stop or be aware of every car that does it ).
A saw with drips blowing out is a point source. You can easilly see it and mitigate it.
ie.. fix the stuff we can fix...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
2017 Caterpillar 326FL Hydraulic Excavator (A53421)
2017 Caterpillar...
2014 10ft T/A Dump Trailer (A51691)
2014 10ft T/A Dump...
19010 (A55851)
19010 (A55851)
RIGID TOOLBOX (A52472)
