AVC8130 thumb help
/ AVC8130 thumb help #1
Tailrotor
Southwestern, PA
Kubota L45 & Kubota BX 2230 , 2014 RTV X 100C
Avc8130
Here are a couple pictures of the pin and bushing and the thumb itself the measurement you ask for is 14 inches. image.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpg
/ AVC8130 thumb help #2
Tail,
Not trying to be a pain, but I actually need to know how wide the bucket coupler would be WITHOUT the thumb.
You have what kubota considers the proper quick change coupler for our machines. Mine is archaic from the l48. If the outside dimensions of the couplers are the same, I'll be golden.
Ac
/ AVC8130 thumb help #3
That's the dimension I'm looking for.
I'm HOPING it is ~10 1/4".
ac
Avc8130
Ok now I see it was hard to tell from your picture from the PM. I just went out and measured it is 7 1/8 inches. Not 101/4 this is from out side bushing to bushing
/ AVC8130 thumb help #5
Avc8130
No way we are on the same page. I'm having trouble communicating the dimension I need.
I can see from your first pic with the tape measure that the thumb bushing is ~1 1/4". If the overall outside/outside is 14", and there is a 1 1/4" bushing on each side...the measurement I am looking for should be 14 - 1 1/4 - 1 1/4 = ~11 1/2".
I need to know how wide your setup would be if you did NOT have the thumb.
ac
Avc8130
Got it sometimes I just need a little extra push lol!!! Mine measures 11 1/4 not 10 1/4 should be and easy fix if you have to build it up for the thumb
/ AVC8130 thumb help #7
That is definitely the better direction. I can turn a pair of 1/2" spacers to make that work easily enough.
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
(2) 4 WAY WRENCHES (A64276)
(2) 4 WAY WRENCHES...
2007 CM TRAILER 18' T/A ENCLOSED TRAILER (A65643)
2007 CM TRAILER...
HEIN-WERNER 1TON TRANSMISSION JACK (A65643)
HEIN-WERNER 1TON...
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
