Use of rear wheel spacers on L3200
   / Use of rear wheel spacers on L3200 #1
vicory
Member
Central Kentucky
Yanmar 220D
Purchased a used L3200 in July which was equipped with R1 ag tires. Most of my land is hills and it feels for lack of a better term Tippy to me. Called dealer and set of R4 tires and wheels are no cost prudent. Read some post about wheel spacers. Seems like a possibility but worried about bearing and axle stress. Has anyone used on a L3200? I was thinking 2", preferably 3". Also any recommendations where to purchase them?
   / Use of rear wheel spacers on L3200 #2
Are your wheels set as wide as they'll go? I have a L4400 and have the wheels set next to the widest arrangement and it is very stable.
   / Use of rear wheel spacers on L3200 #3
Do you have wheels set out as far as possible
   / Use of rear wheel spacers on L3200 #4
Are the tires loaded? Adding weight to the rear wheels is what takes away the tippy feeling. Wheel weights are good, but to lower the center of gravity the most, fill the tires. CalChl (salt water) is the heaviest, but will rust the rims unless you have tubed tires. Rim Guard (beet juice) is next heaviest but more expensive. Even water will help. If you ever freeze, you might want some washer fluid or RV anti-freeze. The spacers will enhance any effect the added weight gives.
Yes, tires are filled and have the wheels set at widest point.
Yep. AGs set all the way out, filled and 3" Motorsport-Tech spacers here.
Good reading....
http://www.tractorbynet.com/forums/owning-operating/322284-wheel-spacers-weights-slopes.html
Thanks number9L. I had read the thread before. Your land and hills are similar to mine. I might have one area that is slightly steeper. I mowed it with no issues for 12 years with a Yanmar 220D but it's about 4 inches shorter in height and had turf tires so it's about same width as the L3200 with R1's at widest placement. I gather you've had no issues going to the 3" spacers. I think I'm going to give them a try.
   / Use of rear wheel spacers on L3200 #8
No issues at all with them. Got about 300hr on tractor. My 5" spacers will be here Thur. Little concerned about the 5" spacers, but they openly sell 4" on the website and I know they've made 5" for the L series for others. The 5" will probably be fine as I don't put a lot of heavy load on the rear of my tractor. At most a 700# box blade or grader blade.
   / Use of rear wheel spacers on L3200 #9
I got spacers for the L3800 (same tractor as yours except HP) through my dealer for use with chains. No problems. The spacers were optional through Kubota in 2011.
Very stable with loaded tires and spacers.
   / Use of rear wheel spacers on L3200 #10
Another thing that works wonders are cast iron wheel weights. I mounted some on my Ford 1710 which is close to a L3200, and I could not believe the difference.
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
