tiller parking stand
/ tiller parking stand #1
kevin maclaughlin
nova scotia
2013 Kioti ck20s hst
Just bought a new woods equipment tiller.Can anyone tell me the purpose for the parking stand which is attached to it.The manual that came with it says nothing about it but searching online it says it is useful for easier attachment hookup and for storage purposes.Should I put this on every time I take the tiller off the tractor or just use occasionally.Thanks for your input.
thanks for the welcome,enjoying this web page and hope to get an answer on the parking stand as well.All the best from nova scotia,canada
/ tiller parking stand #4
Does it have multiple holes so that you can slide it up out of the way? That is how my Woods grader blade was.
/ tiller parking stand #5
I should add, my King Kutter rotary tiller is balanced so well, it stands without extra support. Even sliding the PTO shaft in or out effects the balance.
yes,it has slots but not sure if I try different ones if it will be out of way.Thanks for the help,i will try that tomorrow morn to see if that works or if I will have to remove.
/ tiller parking stand #7
I could see it's purpose if it nose dives every time you unhook. Probably the result of someone getting smashed between the tiller and tractor. I have a very old and heavy Howard rotovator and gravity could get you when hooking it up.
thanks for the info
/ tiller parking stand #9
Depends on how you have the depth skid adjusted if you set it to max tilling depth they sit on tines not skids and will roll forward making it hard to hook up be happy its there even if you don't use it.
/ tiller parking stand #10
Leave it on all the tiller all the time, but raised when actually tilling. It is there for parking in a relatively stable position. I block mine so it won't roll backward or forward in case the kids or grandkids happen to be messing around it.
/ tiller parking stand #11
I use the stand on my Woods tiller when the unit is disconnected from the tractor. I place 4x4 wood blocks on the ground and set the tiller skids on these to get the unit up off the ground for storage. On the side of the tiller with the parking stand, use a long 4x4 so the stand foot can rest on it as well.
My tiller manual doesn't say anything about the stand, other than illustrations of it. :)
/ tiller parking stand #12
Just don't forget to raise it in use. It bends pretty easily.
/ tiller parking stand #13
You're doing exactly as I always did with my Bush Hog brand tiller.
thanks,i raised it to its highest position and now its out of the way
/ tiller parking stand #18
Yes. Mine (without a kickstand) falls forward when I pull away from it. I man-handle it into position when hooking back up but a kickstand might be nice.
have to use a wrench everytime to loose or tighten but not all lost,would be nice if it had a quick change pin instead
