hey guys I appreciate all the information. I bought a 12 volt coil and there is no ballast resistor. I was wondering about that because everything I have read says I need one but I have checked and there is not one anywhere. Does anyone have a good part number for resistor? as for the coil, the original one broke while taking little top bolt off so had to get a new one. the one I have now is a BWD E58, bought all parts at O,Riley s the first time. The new points are Echlin from Napa, have a coil coming in from same place, neither are in the machine yet.
Now I never saw a set of points before this adventure but the original ones in the tractor looked rough, I pulled from my limited knowledge dealing with burnt plugs. the ones in there now look rougher and the spring on the coil is completely black after running it twice, (big oops) i did not put lubricant on point contacts? As for it being a 52, that's what i was told, it is definitely a front mount. plan on looking up number to confirm. testing ignition has me sort of lost, i read something about it but was unclear on procedure. do i disconnect the wire on the coil and then replace with jumper from battery positive?
I rebuilt the carburetor(I briefly impressed myself), found that the screen in the carb elbow had literally fell apart, into the carb i suspect. I am pretty sure I have the fuel going, but would like to know more about the test with ether? sounds like i need to install resistor and test ignition before i do anything else? does that sound like a good second beginning? I am removing housing and doing this work, have had it off three or four times and back on so I am getting lots of practice lining that back up. Thanks guys for your help! I find myself adding this stuff to the list of things I should have listened to pops about but didn't have time!
