Tire explosion kills farmer.
/ Tire explosion kills farmer. #42
Worked on aircraft in the Navy. Used to fill up their tires with portable nitrogen tanks on the flight deck. Anyway, long story short, we were trained to always position ourselves away from side walls, more in line with the treads or at a somewhat 45 degree away from them with no major body parts in the sidewall path. Most tires blow on sidewalls and the most serious injuries occur from their failure. To this day, even when airing up "lower" pressure tires, I always position myself outside the sidewall blast zone. You just never know when a failure can occur.
/ Tire explosion kills farmer. #43
This is why I'd never touch one of the tire chucks that latches on to the valve stem. Bad news...
Take 2 steps to the side to grab a wrench or something, get distracted by something else.... boom!
/ Tire explosion kills farmer. #44
i don't mind the latching chucks.. but i only like them as a leader on a grip valve with pressure gauge, so when you relesae the grip.. it stops airing.
and I like about a 6' lead so i can stand away
/ Tire explosion kills farmer. #45
i don't mind the latching chucks.. but i only like them as a leader on a grip valve with pressure gauge, so when you relesae the grip.. it stops airing. and I like about a 6' lead so i can stand away
Good plan. That's the same way I use mine.
Terry
/ Tire explosion kills farmer. #46
I wonder if the tire was on a loader tractor. A lot of folks run higher pressures on front tires on loaders.
/ Tire explosion kills farmer. #47
I'm confused. Is it safer to add air to a tire with the weight of the loader on it or off it?
/ Tire explosion kills farmer. #49
Just this last year in Clifford a man I knew was trying to air up a rear tire (for a tractor) and when he had trouble with it he sprayed ether into the tire and threw a lit match on it. The explosion will seal the rim but there's a chance the tire might not be able to take it. And, in this case the tire couldn't take it and the man died from impact injuries. He was only about 40.
While we are on the topic of tire safety and fire, this is a video worth watching and remembering. https://www.youtube.com/watch?v=jBUVzgCHHuA
/ Tire explosion kills farmer. #50
it sounded like a rear tire to me.
/ Tire explosion kills farmer. #51
Back in the late 1960s, I had a friend who worked for a trucking outfit that did their own maintenance. The owner had a reputation for being real stingy when it came to tools and equipment. So, one day I stopped by the shop and there for all to see was a brand new, bright green tire cage. Surprised, I asked my buddy about it and he pointed at a split rim stuck in a header over the main door. The fellow who'd been filling the tire had a badly broken arm but was lucky to be alive. Sorry about your friend.
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
213065 (A64276)
213065 (A64276)
3Pt Disk (A66285)
3Pt Disk (A66285)
2010 John Deere 7330 Premium (A64126)
2010 John Deere...
Timpte Hopper Bottom (A63688)
Timpte Hopper...
2024 JCB 35Z-1 EXCAVATOR (A65053)
2024 JCB 35Z-1...
