I would recommend you take a few minutes to go over and under your tractor visually looking for wayward hydraulics that were not ty-wrapped up properly by the manufacturer or setup dealer if they added stuff on it
if you want a 3" wider rear wheel stance... swap your right rear wheel for your left and vice versa!!! The rims are off set and swapping them gives you an extra 3inches
You are right, the power beyond hoses that lead to the rear of the unit were not fastened and hung loosely under the tractor. I happened to have some huge zip ties and secured the 2 hoses to the sub-frame. Thanks for sharing that bit of info!!! Guess when they installed the backhoe they cut corners in the buttoning up department. Something as simple as a dangling hydraulic hose could get snagged and create a headache.
Never looked to see if the rims could be installed differently. I was thinking that the holes that surround the studs could not be inverted? Perhaps the holes have no flange/taper for the lug-nuts to lock against? I will have to run a lug-nut off to see how it is set up. I would be interested in gaining a wider stance for stability though...
